Cruise Control question
Old Oct 27, 2013 | 08:54 PM
Duck Soup's Avatar
Wondering what controls the cruise control on an 01? Mine is not working for the most part. It seems to try, a little urge and then cuts out. Is it a vacuum system or electronic? Also I don't know if the two are connected but my temp control has no variance. I get full hot or full cold only. The temp **** when at the top dead center position is the breaking point, one notch either way and the blend motor moves all the way over. It has the Heat Treater fix and that connection is solid.
Old Oct 27, 2013 | 11:24 PM
SIXSLUG's Avatar
Clock spring manages cruise in an 01...
IIRC blend door is vacuum actuated, pull control panel and check vac lines on rear of switch as a starting point...
Refer to a factory service manual.
Old Oct 29, 2013 | 05:20 AM
wilderness's Avatar
I had a vacuum elbow collapse and keep mine from working on my first 12v. Do a thorough vacuum test.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
Goodys1ton
Aug 28, 2005 01:25 PM
dieselcrazy
Apr 7, 2003 09:36 PM
TexasDiesel
Dec 27, 2002 10:47 AM
