Loose side mirror ?
Old Jan 8, 2003 | 09:18 AM
sdgunslinger's Avatar
Loose side mirror ?
The passenger side mirror on my 97 is loose in it's mount and sort of flopping around at times . I would presume there is a bolt or nut underneath the plastic cover to adjust the tension , but the cover doesn't appear like it wants to pop off of there very easy . Is there any special trick to getting the cover off without wrecking it ?
Old Jan 8, 2003 | 12:35 PM
pappyman's Avatar
Re:Loose side mirror ?
Theres a writeup about it in the Tech Facts<br><br>http://www.dodge-diesel.org/faq/faq....p;onlynewfaq=1
Old Jan 8, 2003 | 01:37 PM
Captain's Avatar
Your in luck.. sort of. My life long best friend is the guy who tests the chrystler mirrors and his dad has the patents on most of them. Actually if you have a 97 you can replace them with the mirrors off a 98 if you prefer that look. So I asked him.. this is what he says.<br><br>Me: The passenger side mirror on my 97 is loose in it's mount and sort of flopping around at times . I would presume there is a bolt or nut underneath the plastic cover to adjust the tension , but the cover doesn't appear like it wants to pop off of there very easy . Is there any special trick to getting the cover off without wrecking it ? <br>Me: anyideas so I can look like a big man?<br>Him: there are 3 nuts behind that panel actually<br>Him: however I think you might have to get the whole **** door panel off<br>Him: let me go check<br>Him: yeah if I remember correctly, your door panel and that part behind the mirror are all one piece. I think there's one screw toward the front of the truck near the mirror you can take out but the rest of it is fir tree clips. If you can take that front screw out you may be able to pry back that part and get in there with a 10mm socket<br>Me: right<br>Me: Sounds good<br>Him: I think the torque is 60in/lbs fyi<br><br>Hope that helps.
Old Jan 8, 2003 | 06:08 PM
gitchesum's Avatar
Here ya go. Everything you need to know to fix it.<br><br>Man, Dave Fritz is a saint ain't he?<br><br>http://www.dodgeram.info/tsb/1999/08-30-99/08-30-99.htm
Leaky Gasket
Aug 14, 2008 07:17 AM
capsparky111
Feb 5, 2008 09:34 PM
xzlram
Mar 1, 2003 08:59 PM
Buzz
Nov 19, 2002 09:49 PM
