Location of AC condensate
Old Mar 21, 2003 | 08:27 PM
Tackdriver's Avatar
Help<br>Where is the condensate vent for the AC unit on a 1998 3/4 ton Ram? I think it is plugged, and I want to check it, as I get condensate all over the floor.
Old Mar 21, 2003 | 10:40 PM
Stamey's Avatar
Re:Location of AC condensate
You should see it of you get up under the right side or the frame, behing the tire. Look between the inner fender and the frame at the back. The hose probably isn't very long because it just drips on the plastic inner fender and rolls off.<br>A coat hange stuck up in there should unclog it.<br><br>Chris
Old Mar 23, 2003 | 09:19 AM
Stamey's Avatar
Here are some pics.<br>This pics is from the bottom of the truck, looking between the right frame rail and the right inner fender, behind the front wheel.<br>The red line points to the vent tube, and the blue line points to the filter drier.<br><br><br>In this picture, you can see the position of the filter drier in the engine compartment. It is the black object mounted on the firewall, with the green plug on top.<br><br><br>The AC evaporator vent is just under the filter drier.<br><br>Chris
59FORD
Apr 7, 2006 12:28 AM
simonswb6
Nov 4, 2002 09:24 PM
NWDave
Oct 26, 2002 09:29 PM
Jbolt001
Oct 26, 2002 02:20 PM
