Front brakes
Old Feb 21, 2003 | 11:39 PM
Mr. 45's Avatar
Front brakes
I am in need of new front pad's, Has any one used the one's from napa? What do you use? Semi-metalic or metalic? What have you heard about the ceramic one's? I don't know if i need new rotars yet, Guess i will find out when i tear it down and measure. Do you have any pointer's for a break job? Thank you for any help.
Jon
Old Feb 22, 2003 | 12:24 AM
rich's Avatar
Re:Front break's
Napa pads work prety good the ceramics will eat your rotors from my understanding. the metallics will work get the haevy duty type try not to turn the rotors if possible in order not to thin them out and check for deep heat fractures
Old Feb 22, 2003 | 01:36 AM
BigK's Avatar
Re:Front break's
Sam Peterson put togerher a special package for our dodge rams.<br><br>Carbomet's are first class<br><br>Call and talk to Sam 360-357-4958<br><br>you will be glad you did <br>---------------------------------------------------<br><br>Thanks Bob Wagner<br>
Old Mar 21, 2003 | 02:16 PM
powerwagon440's Avatar
Re:Front break's
Does Carbomets have a website if so what is it thanks!
Old Mar 22, 2003 | 08:03 AM
Bill1374's Avatar
Re:Front break's
Jon,<br> Just put my second set of NAPA pads on. This set had 40k on them and still had pad left. Considering that over a third of that is with a 12 k fifth I'm well satisfied with their service life. <br><br>Bill
Old Mar 22, 2003 | 08:24 AM
atc250r's Avatar
Re:Front break's
I just put a set of the NAPA ceramics on, truck stops much better. Be sure to clean and adjust the rear drums while you're at it, mine needed about 25 or 30 clicks to get them up to where they should be, now the pedal is nice and high.<br><br>John<br><br>
Old Mar 23, 2003 | 10:14 AM
casey's Avatar
Re:Front break's
there are only a couple of makers of brakes Raybestos,and Wagner. so wherever you buy them just make sure they come w/a lifetime warranty and YES ALWAYS turn your rotors if you stand there and watch them turn i will Guarantee you'll see a warp taken out . It's a little more work but it gives you a supreme job CASEY ASE brakes &amp; front ends
Idaho Guy
16
Feb 12, 2020 11:15 AM
donsharp1959
Dec 15, 2011 12:40 PM
big jimmy
Jan 29, 2006 11:17 AM
wildcargo
Nov 29, 2005 04:20 AM
