water in fuel light sensor location
Old Nov 4, 2002 | 08:25 PM
simonswb6's Avatar
i have a 1995 ctd<br><br>my water in fuel light will not turn off. i have drained the water several times from the bottom of the filter... i have to assume that the sensor is bad...<br>where is the sensor located?
Old Nov 4, 2002 | 08:42 PM
berner's Avatar
Re:water in fuel light sensor location
The Water in fuel sensor is located on the bottom of the fuel filter. The drain that you lift up on has a couple wires coming out of it that you have to disconnect in order to change the fuel filter. My '96 didn't have one when I bought it. It had a plastic fitting that you had to undo to drain the filter. I foolishly went to the dealer to get the proper one. Paid way too much. Geno's has them for $15.95. Geno's You could also check you're wiring to make sure it's not grounding or shorting out somewhere. Good Luck.
Old Nov 4, 2002 | 09:24 PM
phox_mulder's Avatar
Also might try wiping the actual sensor in the bottom of the filter cannister.<br>It might be buggered up with something.<br><br><br>phox
dart3404
Oct 12, 2009 03:35 PM
59FORD
Apr 7, 2006 12:28 AM
tyssniffen
Feb 11, 2006 01:28 PM
acker1
Jun 30, 2003 03:13 AM
