Lift done wrong....
Old Feb 2, 2003 | 12:18 PM
4x4's Avatar
4x4
Lift done wrong....
Not sure if this is the right spot ??? but here it goes. My buddy just installed a Skyjacker 2.5&quot; suspension lift on his '98 2500 4x4 cummins(obviously). He did it by himself and it seems to be sitting HIGHER in the front than in the back!!! My question is do the coils need time to settle or did he do it wrong?<br><br><br>P.S. thanks for the info.
Old Feb 2, 2003 | 12:54 PM
doodah's Avatar
Re:Lift done wrong....
did he just lift the front? or what? some times if you put in a front leveling kit in a truck that does not need it, it will sit higher in front! commen fix is ad another leaf in the back!
Old Feb 2, 2003 | 01:57 PM
4x4's Avatar
4x4
It was an all around lift with a single add-a-leaf spring in the rear that went on top of overload spring on bottom of pack. I think he said it was supposed to re-arch the whole pack sense it has a higher arc to it?
Old Feb 2, 2003 | 08:17 PM
TX Ram's Avatar
The front coil springs will settle a lot after driving it a few days.
Old Feb 2, 2003 | 08:52 PM
DF5152's Avatar
if the rear spring was added in the overload pack it will not do anything till the overload springs hit there stop.<br><br>Dan
Old Feb 2, 2003 | 09:43 PM
4x4's Avatar
4x4
No, they were put under the main spring pack.
Old Feb 2, 2003 | 09:48 PM
BAD HABIT's Avatar
When I was a kid. The tough looking 4x4s were higher in the front.This was cool then and to me still is. I install 2in. leveling kit just to get that look. 8)
Old Feb 2, 2003 | 11:57 PM
kingofdodge7131's Avatar
I do have a question to go with this. I look out there and find trucks that say skyjacker 10 inch or someohw have a 10-15 in suspension lift alone... But when i went out shopping ( havent bought yet) all i could find were 5 in lifts as the largest.. where or how to you get the 10 in lifts?
Old Feb 3, 2003 | 05:14 PM
gunracer1's Avatar
that is all custom stuff when you get in the 10+ lift or more. you can get a 5 or 7 and a 3&quot; body and clear just about anything you want to run. just trim some sheet metal.
Old Feb 4, 2003 | 12:33 AM
oldred97's Avatar
If the truck had a factory snow plow package this could be the cause for the squat in the rear. All snow plow package trucks I've ever seen have done this a little. Just a suggestion though.
Old Feb 4, 2003 | 03:41 PM
Idaho CTD's Avatar
I believe the 98-2000 trucks had a smaller block between the rear leafs and the axle. My 99 sat fairly level stock. If you/he got a kit for a newer truck it may be the reason the front sits higher. He could get the larger blocks, call Skyjacker about it (their customer service sucks), have his springs rearched, or live with it.<br><br>Just my 2 cents<br>Nathan
Old Feb 4, 2003 | 08:25 PM
RAMTECH's Avatar
I dont have an answer for you but I have a question on the same subject. I am going to put a 5 inch on my 2500 ctd. I have heard that the steering becomes loose on some of the 2500's. Something to do with some of the components not being able to handle the weight. Anyway are there any other mods I should make when I install the lift to keep this from happening down the road.<br><br>RAMTECH
6.7L MegaCab
30
Nov 10, 2011 10:36 PM
pwrtripls1
Jun 6, 2010 10:26 AM
corey88
Jun 17, 2008 05:16 PM
mainer
Oct 23, 2007 02:42 PM
Ramdriver15
Jan 24, 2007 09:33 AM
