instaling leveling kit help
Old Jul 28, 2012 | 09:09 PM
joem's Avatar
Figured Id tackel this myself, 2" leveling spacker and I have the axle down as far as I can with the brake and vacuume lines tight. I barly was able to remove the spring much less put it back in with the spacer, its not even close! what am I missing? I bought a spring compresser and i took it down a inch with it but im a bit timmid to really crank it in- what tricks does everyone use?
Old Jul 29, 2012 | 12:22 AM
DC199512V87's Avatar
i used regular 1" ratchet straps and cranked them down till i thot they would break then some more. then use 3' prybars as well. very sketchy at best and its definitely not safe but got the job done. its up to u when u feel its not safe anymore. id say with the spring compressors (right tool for the job) go ahead and crank them up. o btw i put a bottle jack between the frame and axle and gave it another inch. but b very careful there....ur lines are tight already and u run the risk of wrecking the swaybar linkage like i did
Old Jul 29, 2012 | 12:05 PM
joem's Avatar
Im half tempted to pull the calipers and unplug the vacuume+electrical and just pull the darn control arms off this thing, I plan to install energy control arm bushings and get it alinged anyway- just use the rachet straps to catch the axle as I start pulling the arms?
Old Jul 29, 2012 | 01:12 PM
Hodge's Avatar
I just put a 2" level lift on my 94. I used a standard coil spring compressor, which installed inside the coil. It compressed them enough to get in without having to disconnect brake lines. I did pull the vacuum line lose for the CAD. There is no doubt that it can be done.
I also had a set of compressors that worked on the outside of the coil, which I didn't like.
I also used a jack to force the axle down as far as possible, without hurting the brake lines. The coils came out and slid in fine.
Old Jul 29, 2012 | 02:35 PM
I used the ratchet straps to compress the coil.....
Old Jul 29, 2012 | 10:09 PM
joem's Avatar
Got them in, Ended up putting on my dirt bike full face helmet & riding gear and chest protector. Cranked the impact gun up to 500ftlb and cranked that coil down, I could have gotten 3 spacers in there after that
I kind of wish I got the 2.5" spacer as its still not level, but man it does ride like a new truck with the Bilstein 5100's
sgtdiesel
25
Jun 26, 2012 02:37 PM
06Cummins
19
Jan 5, 2007 03:27 PM
mkinla
Jan 14, 2006 05:56 PM
0425004x4
Dec 4, 2005 06:29 PM
smokindog
Jul 16, 2005 08:01 PM
