Help! Had leveling kit installed and now i have a poping in my steering..
Old Nov 27, 2006 | 10:00 AM
06Cummins's Avatar
I had a top gun customz levling kit installed and some new BDS shocks. Now at slower speeds (usually) i am getting some poping when i turn the wheel.. most noticable is at slow speeds or accel from a stop and turning my wheel to the left. it happens very quickly after turning the wheel only 3 inches or so...it is also doing it at other times like slow speed turns to the right when im about half way to lock. can anyone give me some advise as to what i could do. the guy that put on the levling kit is telling me that whatever he did wouldnt have effected the steering...i would take it back but im in college station and it was done in fort worth over the hollidays. On top of that the fron suspension is also squeaking like crazy...any help would be awesome...thanks, Jason
Old Nov 27, 2006 | 10:04 AM
JD Dearden's Avatar
Could be alot of things, I think you need to figure it out because it will drive you nuts until you do, I would have them start by re tourqing everything.
Old Nov 27, 2006 | 10:09 AM
ataboy9026's Avatar
You may want to check to see if it is the shocks loose. The bolt that holds them will get tight before actually squeezing the rubber gromet of the shock and it will "dance" up and down until you tighten it more. I took a large prybar under the shock end and pryed up off the axle housing to see the movement and tightend bolt till there was no more movement. I think the aftermarket shocks rubber bushing/sleeve is just narrower than factory and you have so slightly "bend" the bracket as you tighten shock bolt so the new one won't move around. At least that was my noise.
Old Nov 27, 2006 | 10:11 AM
06Cummins's Avatar
thats the thing..they cant do it..im 3 hrs away and cant get back...just looking for what i can do..yea im going to go over everything..just trying to see what the most likely culprit is? Would something be going out with my steering box already?..truck only has 5,000 miles and it didnt do this before the kit was installed..
Old Nov 27, 2006 | 10:25 AM
06Cummins's Avatar
thanks ataboy...ill look at that..
Old Nov 27, 2006 | 10:28 AM
Patriot2500's Avatar
I had the same thing when I installed my leveling kit. Turns out the bolts came loose and it made the noise when I turned the wheel slightly. Try that first, hope it works for you.
Old Nov 27, 2006 | 10:36 AM
Speed Shift's Avatar
Hey man, it might be your track bar. I went through a couple of those on my 2000.
Does it do it when it rocks side to side?
Give me a call and I can take a look at it for you, I might be getting my FASS today also... just shoot me a PM.
VERY IMPORTANT!! Check your tie rod ends, and steering links, you dont want those things comming off going down the road.
Old Nov 27, 2006 | 10:38 AM
morkable's Avatar
Have somebody turn the wheel while you lay on your back under the front and watch everything move,, you will see what is wrong allmost immediately
Kevin
Old Nov 27, 2006 | 10:51 AM
06Cummins's Avatar
patriot, are you talking about the 3 bolts ontop of the shock tower?...yea it squeaks when it rocks back and fourth but doesnt pop...what are you up to later..lol might bring it over to you and see what ya think..
Old Nov 27, 2006 | 10:53 AM
cquestad's Avatar
It is most likely your panhard bar...or track bar. The one that is parrallel to the axle. They need to be as tight as a breaker bar can make um!
Old Nov 27, 2006 | 11:34 AM
CDoskocil9's Avatar
Its your track bar mine does the exact same thing with my Kore lift its because it isnt long enough..... Im not sure if something was changed in 06 but the bushing in the track bar is not very strong mine is wearing out fast causing noise...... Try putting a good lubricant or grease on it and I bet it goes away.... Only true fix would be new trackbar.
Old Nov 27, 2006 | 11:54 AM
973604x4's Avatar
well heck we are having loads of fun here at TAMU! flex plates, steering components...fun fun fun.
Yes SPEEDSHIFT wants to rip my FASS off tonight so we'll already be playing with trucks. SPEEDSHIFT's diagnosis wasn't right last night though...gotta watch him we were close just never got around to pulling the bell housing cover
I would have to say track bar....these trucks are notorious for them. theres several aftermarket solutions.
Old Nov 27, 2006 | 01:57 PM
Diesel-Dan's Avatar
Check shock eyelet bushings....though these would be more of a rattle than Pop. ANY loose or slightly loose bolt could cause this. Seen it all the time at the Nissan Dealer on suspention items. BUT Panhard Bar (Track Bar) would be tops on my list......have someone cycle the steering and look at the ball and socket end to see if there is ANY play....also keep an eye on the bushing end...i have seen thoes ware funny and have play as well....I was lucky enough to get "Death Wobble" on mine...to force my wife into letting me have a TBK and an '06 pandhard bar out of our shop truck! haha......
Tierod ends.....look at them...but usally don't pop....if they are greased...and you would notice the 1/2 turn of play in the steering if it got to that point! Shouldn't be too hard to find......just use a friend to help you look under the fnt end when cycling the steering.......
Old Nov 27, 2006 | 02:03 PM
973604x4's Avatar
This friend will help! Jason call me tonight if you need any help...ofcourse...i can't come to you right now...dern flex plates
Old Nov 27, 2006 | 02:30 PM
Hey hey, its not fixed yet... you are real lucky with just a flex plate. I was telling my pops about it and he said he has had them go through the floor I sure do hope thats all it is though, now is you opportunity to upgrade the output shaft also.
I cant wait to get my hands on that FASS either I wont rip it off, it will be professionally removed.
Later Buddies
