Leveling Kit Install Help???
Old Jul 16, 2005 | 12:08 AM
smokindog's Avatar
Question Leveling Kit Install Help???
Does anyone have any words of advice for installing the 2" leveling kit. I tore the front end down tonight and there is absolutely no way the springs are going back in with the 2" kit in there. The front axle cannot drop anymore as the link arms are bottomed out on the brackets. I even went so far as to disconnect the sway bar links and it only helped gain another 1/2". Spring compressor?
I know there is some trick to this as I have done my share of coil replacements on other vehicles, but they all just slid right in. I'll patiently await any ideas. Truck is OOS until I get this squared away.
Old Jul 16, 2005 | 02:09 AM
Cowhand's Avatar
Did you do the 2" spacer? Never heard this one before...usually you can pop them in with a pry bar.
Did you D/C the track bar? If that doesn't work, disconnect the upper CA at the axle end one side at a time (disconnect one side, put the spring in, jack up the axle and connect the upper CA, then do the other side.)
Sounds kinda strange, I put 6" springs in without a spring compressor by disconnecting everything except the CA's. Had short arms too.
Good luck with it....
Old Jul 16, 2005 | 04:43 AM
95ram's Avatar
When I put my D25's in I used a bottle jack between the axle and the bump stop. They went right in.
Old Jul 16, 2005 | 07:15 AM
shoe's Avatar
when I did my D25 I went to the local auto parts store and rented a spring compresor and they went right in.
Old Jul 16, 2005 | 10:27 AM
SuperDave4x4's Avatar
That's exactly what I did also. Just go rent a spring compressor, it'll be easier.
Old Jul 16, 2005 | 10:51 AM
BigBlue's Avatar
The way I've always done them is you just have to man handle them in. Have someone push down on the side of the axle your working on and push up on the other side while you push the spring in.
Old Jul 16, 2005 | 03:07 PM
smokindog's Avatar
Got R Done Guys
I ran up to AAP this morning and borrowed their spring compressor. It helped just enough to get the springs back in.
Thanks for the help!!!
Old Jul 16, 2005 | 03:55 PM
genros's Avatar
leveling kit
Hey guys,
the leveling kit is for looks only ? will it help with a plow whats the deal. Im in a 01 2500 xcab
Old Jul 16, 2005 | 06:02 PM
erics76's Avatar
use the bottle jack, it's free. It's worked for me on my 2500 and my parent's jeep tj.
Old Jul 16, 2005 | 08:01 PM
Marine's Avatar
Veteran: Marine Corp
Re: leveling kit
Originally posted by genros
Hey guys,
I suppose it would give you the 2 inches back that you lose with having the plow on.
Mike
sgtdiesel
25
Jun 26, 2012 02:37 PM
RobV2500
FLDTR #23
Jan 29, 2009 07:39 PM
oregon ram
Jul 21, 2004 06:11 PM
roadie00
May 18, 2004 10:25 PM
Gordonville
May 14, 2004 11:21 PM
