How hard is it to convert a 3500 to a 2500?
I have been looking for a 94-98 extended cab 4x4 long bed 5 speed for awhile now and the only ones I have been able to find in my area worth looking at are all duallys. I was just wondering what all would take to put a normal bed and single rear wheel on a 3500 truck?
the front axel you will just have to remove the hub extension, not a big deal.
on the rear, i thought i remember reading the drums were a larger diameter on the drw. not sure if you would have to midify the rear any further.
the rear axle is a couple of inches wider, really not that big a deal. you will need a 3/4 ton bed, the dually beds are cut up for tire clearance beneath the fenders. the front spacers are easily removed with a wrench. and get the 3/4 ton fuel filler/neck.
Oh yea, one more thing, make sure you get a dually, not a cab and chassis model. The CC models frame is slightly different ( Wider,IIRC ).
Had a buddy put a dually bed on a 98 4X4 CC, but he had to make adapters and it never looked quite right. ( slightly larger than normal gap between bed and cab.)
hope this helps.
IIRC, I measured the rear axle width at 78" or so, WMS to WMS. Front was 79" I think.
Idaho Guy
Nov 6, 2011 03:09 PM
gts95
May 26, 2009 02:24 PM
roxxx
Apr 13, 2009 05:15 PM
