heater core?
Old Dec 10, 2008 | 03:13 PM
mr bill's Avatar
heater core?
Is there any way to change the heater core without evacuating the A/C? Maybe through the dash?
Old Dec 10, 2008 | 03:34 PM
1-2-3's Avatar
Just a plain ole guy
Nope. The heater core and evap core is in the same box. The box has to come out and be opened up to get either of them out. Do yourself a favor. Replace the evap and accumulator while your doing this. Add 1 ounce of oil per part replaced. Also add three 3/4" ball valves. One each on the in/out of the heater core, and one as a bypass across both hoses. in the summer, close the in and out and open the bypass. it will stop the flow of hot coolant and make your air colder and your ac will work a whole lot less. And do one more thing. get a hose and shove it onto the condensation drain tube and route it down and zip tie it to the frame. This will prevent the inevitable condensation leak that will happen one day.
Also, the evap coil either is leaking or will leak. Just a matter of time. Go in once, change it all and be done with it.
Old Dec 10, 2008 | 05:44 PM
johnh's Avatar
re charge with propane
Old Dec 10, 2008 | 07:10 PM
ramsport59's Avatar
YES the heater core can be changed without doing the A/C. Just did it this weekend, the heater core slides out the top. The new heater cores have Swival(sp?) ends on them, so You pull the dash back, take out all the heater box bolts and slide it back 2 inches. Cut the old heater core lines inside the truck, slide it up and out. You can fit the new core in once you find the right angle.
Rick
Old Dec 13, 2008 | 09:18 AM
mrclean's Avatar
Huh? I don't get it.
Old Dec 13, 2008 | 10:47 AM
olddodgetrucks's Avatar
i thought i was the only one that used propane
Old Dec 13, 2008 | 04:03 PM
johnh's Avatar
nope i use it in my dakota, but it leaks out in about three weeks... i'm too lazy to fix it i just put more in
Old Dec 13, 2008 | 04:31 PM
MoNStrRIg's Avatar
Yup, I had a buddy do it, by pullin his dash out.....
Old Dec 31, 2008 | 09:35 AM
oudive's Avatar
Not sure if you have tackled the heater core yet. I just did mine last weekend. Did not discharge the A/C, it is just time consuming removing the dash enough to get to the heater core. I did not pull my whole dash out, just kinda secured it far enough back to get my arms in there and secured one side with a strap and the other just sat there on the steering column.
Old Dec 31, 2008 | 09:51 AM
Dodge Demon's Avatar
Do a search,this was covered extensivly a couple weeks ago, all you need to know and even more.
canadakonrad
Dec 1, 2010 08:41 PM
wdimig
Sep 29, 2010 07:38 PM
Haulin_in_Dixie
Jan 4, 2004 11:52 AM
cummins24
Aug 3, 2003 06:45 PM
