headlights go off and on i replaced the switch now what??
Old Mar 31, 2007 | 04:57 PM
Racing_Joe66's Avatar
my headlights keep going off and on. i replaced the multi-function switch on the steering column and that didn't fix it. when the lights go out if i pull that switch back to keep the brights and dims on they stay on and if i let it go they will shut off but sometimes stay on bright.
what else is there to do??
thanks
Old Mar 31, 2007 | 07:19 PM
it does it when i am parked and driving both. it was fine after i replaced the switch as i left it on low beams but as soon as i put the high beams on then it started acting up instantly. the volts gauge doesn't move when it does it either.
Old Mar 31, 2007 | 09:04 PM
logskidder's Avatar
If your truck has a tilt wheel, check the wires at the pivot point.
Old Mar 31, 2007 | 10:38 PM
anything else to check out???
thanks
Old Apr 1, 2007 | 02:25 AM
HOHN's Avatar
relay, perhaps?
Old Apr 1, 2007 | 03:21 AM
wcbcruzer's Avatar
yeah, check all the relays and fuses.
Old Apr 1, 2007 | 10:07 AM
where are the relays located for the lights?? are they the ones by the fuse block in the engine compartment?
Old Apr 2, 2007 | 02:55 PM
Sean Allan's Avatar
could it be the day time running light module? Mine died and left the lights on all the time. Located on the driver side fender.
Old Apr 2, 2007 | 03:05 PM
belgianmagic's Avatar
relays in fuse box under hood driver side... you will find thats what it is... they work like breakers
Old Apr 2, 2007 | 05:06 PM
JWFMOPAR's Avatar
Had that happen once, replaced the multi-function switch, didn't help, ended up being the actual headlight switch itself
Old Apr 2, 2007 | 07:36 PM
D2 Cat's Avatar
I agree with JWFMOPAR (man that's a lot to type!). The main headlight switch. Had similar situation with a Dakota. Sometimes the dash lights would be off for a few minutes, sometimes not. Sometimes the headlight would take a dump for a moment. When it happens at 60 MPH it doesn't take long to get motivated to get it fixed!
Old Apr 2, 2007 | 08:21 PM
Scramblinman's Avatar
On my truck only the high beams have stopped working. The relay looks good and switching it with another makes no difference. Otherwise, the rest of the lights work fine, although the headlight switch does feel a little rough when dimming the dash lights. Would a bad headlight switch be able to kill just the high beams?
Old Apr 2, 2007 | 08:40 PM
TIMMY22's Avatar
my headlight switch ended up dying while I was out plowing snow in a parking lot at 2AM. Good thing the parking lot was well lit! I had a terrible oily burning smell when it went. Put a new $17 headlight switch in and all was fine.
Old Apr 2, 2007 | 09:58 PM
ok i found one wire on the multi-function switch connector that was a little suspicious so i fixed it and that didn't help. i found a wire under the dash that was a little suspicious and that didn't fix it. my dad switched two of the fuses in that box around to see if that would make a difference two of the clear ones and that didn't even make a difference.
and i went for a drive tonight and it started doing it all over again.
any ideas??
could the light switch do it?? as it cuts out on the low or high beams both and when i pull the multi switch back they come back on and if i hold it. and some times if i let go they go off and sometimes not.
joe
Old Apr 3, 2007 | 07:48 AM
TIMMY22's Avatar
yes, change the headlight switch.
