headlights go off and on i replaced the switch now what??
timmy22 this horrible burning smell your talking about......
did it smell like varnish or nail polish remover... almost so strong you have to roll down the window?
Where is this headlight stitch you speak of?
My headlights will turn on , but no running lights, and the fuses are all in tact.
man i just priced a headlight switch at carquest and they wanted $120.00 man i just replaced the multi-function switch for $57.00 where is a cheap place for the switch and also any other ideas on the problem??
i went out just a bit ago to take 2 buds home and started the truck and then pulled the **** out to turn the lights on and the headlights didn't come on but the parking lights did. then i pulled the dimmer switch and they didn't stay on so i held it and they did and then let off and they went out again. then finally they came back on. and then we started driving and they went on and off a few times.
what the F_CK!!!!!!!!! this is driving me nuts. i found on the main battery that the positive terminal connector had a crack and didn't want to be tight tight so i replaced that and that didn't help and that was earlier today.
joe
joe
Maybe it's just shooting in the dark but have you checked the ground straps on left side of fender ?
There are 3 straps, 2 underneath washer bottle and one on top or radiator support. If you have any corrosion they might not conduct well and you loose the lights when drawing more power.
I am sure it's not your case but it takes just a minute to check.
what the EDIT this is driving me nuts. i found on the main battery that the positive terminal connector had a crack and didn't want to be tight tight so i replaced that and that didn't help and that was earlier today.
joe
joe
Wow! yours is expensive, here it is at napa...
http://www.napaonline.com/masterpage...adlight+Switch
Here is mine at napa...
Watch the language on here, There are women and children viewing. even if you don't actually spell it out, they will get after you for it.
i have 3 ground wires on the RAD. they were clean as a whissle i will have to see about the one underneath.
i think i might just hard wire the lights with a pull **** switch for the headlights and then a toggle switch for the high beams.
has anyone done this and have a wirring diaghram and an idea on how to do it??
thanks
thanks
So it wasn't the relays or fuses.. How about replacing a bulb? This sort of thing has happened to me twice where a faulty bulb was the culprit. On my last truck, the right headlight would go off and on. Seemed like a short somewhere and the bulb looked fine, but I replaced it anyway... Problem solved. On a Toyota we had, both headlights didn't work except for high beams and it turned out the low-beam filaments burned out. They were dual filament bulbs just like your headlight bulbs.
BTW, this multi-function switch you were talking about, is that the one in the steering column that controls the high beams? Since your ground wires were clean (and you know your truck's condition better than me), I suspect the wires are intact. I'd check those relays and fuses once more and make sure all the terminals are good. There's so many of them they're easy to miss. Also, some relays and fuses adversely affect other electrical components.
