Headlight bulb upgrade anything worthwhile
Old Nov 5, 2007 | 03:01 PM
haloman's Avatar
Some good reading here:
https://www.dieseltruckresource.com/...d.php?t=175441
Old Nov 5, 2007 | 04:02 PM
megajoltman's Avatar
I was reading that will have to check it out.
Thanks
Old Nov 5, 2007 | 04:08 PM
haloman's Avatar
Thanks
I am going to post a new thread when I get it all installed with thoughts and photos.
Old Nov 6, 2007 | 04:07 PM
TNutcher's Avatar
i did this quest too for better lighting. I bought the euro headlights with the clear lens (not sports, single bulbs (around $120)) the summin harness (like 40 bucks) and some 80/100 watt 9004 bulbs from summit as well (like 50bucks) and honestly the best money was in the bulbs and the harness because while the lens's helped out a bit they weren't worth the money in improvement compared to the bulbs and the harness. and honestly some silverstars or piaa bulbs probably work well even if colored in overwattage but i wouldn't touch the blue bulbs in standard wattage that aren't really a trusted name. A set came with the headlights i bought and took a trip to pismo. Driving down the roads, unless there were absolutely no other lights, you could barely tell that the lights were on and it was better to drive by the factory fog lights.
SO i'd go with the summit harness, aim your headlights correctly and buy a good set of 9004's or overwattage 9004's. I've seen overwatts for like 20-30$.
Hope this helps
TNutcher
Old Nov 6, 2007 | 06:38 PM
Thanks
Anyone get busted for the 80w/100 for some reason here I thought only 55w lowbeam was allowed by law
Old Nov 6, 2007 | 07:05 PM
mr bill's Avatar
have been running the 80 watt bulbs for 2-1/2 years and no problems (yet).
Old Nov 6, 2007 | 07:24 PM
TXaggie09's Avatar
I need to get some new lights for mine but i have to get the new lenses and everything, for some reason the previous owner put bondo or somehting over the adjustment screws.... before adjusting them!
What are the recommendations as far as replacement lenses? What all is involved in going with sport headlights?
thanks in advance
Old Nov 6, 2007 | 07:31 PM
Dr. Evil's Avatar
Thanks
That could happen - but I think the police tend to target the guys using the HID bulbs.
Old Nov 7, 2007 | 09:06 AM
haloman's Avatar
thanks in advance
Read this thead here for more info. I've ordered replacement housings, bulbs and HD harness.
Old Nov 7, 2007 | 05:39 PM
MSquare's Avatar
I'm surprised this website hasn't been mentioned http://www.danielsternlighting.com. He is THE guru of automotive lighting!
You can get all of your questions answered from him. He will respond personally and give you his expert recommendations.
I've seen the harness from Summit, el crappo! The one from SUV Light is spendy, but nice. Stern will sell you all of the hardware, minus the wire. This way you can route it were you want it and he sells the best connectors and relays.
Old Nov 7, 2007 | 08:32 PM
Dr. Evil's Avatar
There is WAY too many headlight threads here...
There is some interesting reading on Daniel Sterns website.
Old Nov 9, 2007 | 02:48 PM
sshelly's Avatar
wiring harnesses
Is the wiring harness that summit, lmctrucks, and suvlighting the same harness essentially? Do the harnesses protect the already marginal headlight switch? Stuart
Old Nov 9, 2007 | 04:02 PM
Dr. Evil's Avatar
Yes, thats the whole point of having relays on the harness...
Old Nov 9, 2007 | 10:57 PM
oldblues's Avatar
hi
got a harness from summit and it did improve my lights considerabily !
i have 9004 std bulbs and a diode to allow high and low beams on for high position !
cleaned the grounds real good and used dilectric grease on all connections of harness and grounds !
hope this helps !
Vintage Empire
35
Nov 27, 2010 11:07 AM
barryp
62
Jan 2, 2008 01:01 PM
robert78.5
Sep 28, 2007 10:23 PM
scarecrow
Dec 19, 2005 10:28 AM
Palmtree
Dec 6, 2004 06:09 PM
