Headlight Aiming Screws
Re:Headlight Aiming Screws
I don't believe so. They have a ball on the end, and are molded into the plastic. On mine, the plastic around the torx screw cracked. I had to replace the entire headlight assembly.
The screw can be ordered from Dodge.
If it is the plastic behind that the screw goes into, then you most likely will have to replace the plastic mounting assembly.
crobtex
May 27, 2019 12:19 AM
Lomarker
Jan 30, 2007 08:57 PM
