Hazard switch
Old Aug 12, 2010 | 10:55 AM
Lone Wolf's Avatar
Hazard switch
1999 2500 truck, when I push the hazard button nothing happens. I do know that in the past when I pushed it there was a loud shirking (sp) noise but nothing now. The 10amp fuse on the side of dash near driver door is good. Is there another fuse or (older days there was a big round or square fuse). Going on a camping trip 3 states away and want to get this fixed in teh next few days. Asked the dealership and the answer--bring it in for a fee to fix it!
Thanks
Old Aug 12, 2010 | 04:21 PM
gorms's Avatar
Do the brake lights and turn signals operate normal? Brake lights run "through" the hazard switch, so if they are gone I'd say the switch is dirty/burned out. There should be a flasher in that same fuse compartment, which is what actually causes the delay/flash for turn signals and hazard signals. Should be a fairly easy/cheap item at any auto parts store, and yes I think it is a big round or square plug in deal.
Old Aug 13, 2010 | 09:13 AM
Lone Wolf's Avatar
gorms,
Yes the brake/turn signals all work great. There is a blue square fuse but the owners book doesn't say what it is like the other 10 amp fuses so I was worried about pulling it. I will try that and see what happens. Thanks
Old Aug 13, 2010 | 09:32 AM
johnh's Avatar
Thanks
try changing the emergency flasher
Old Aug 13, 2010 | 09:44 AM
Lone Wolf's Avatar
johnh,
Hi, That is what I am trying to figure out on the fuse panel. According to the owners manual there is a 10 amp fuse but says nothing about the round or square fuse. I am use to the old turck that had a round silver fuse but there is a blue square one but not labeled. So I think that is the one to look at but you would think the manual would state that? Thanks
Old Aug 16, 2010 | 09:51 AM
Lone Wolf's Avatar
Well changed the multi switch on the sterring column--problem solved. Thanks guys, now to figure out the throttle position sensor problem.
Luckycharm1
Mar 10, 2006 09:54 AM
hotdram
Mar 24, 2005 12:33 AM
Ritler
Mar 21, 2005 07:12 PM
Chief2
Jun 11, 2004 02:41 PM
Amish hauler
Mar 19, 2004 10:23 PM
