Has anyone removed the fuel separator lever assembly?
Old Dec 29, 2007 | 09:01 AM
azmusclecar's Avatar
Has anyone removed the water/fuel separator lever assembly?
Just looking for someone who may have removed and/or cleaned and/or replaced the unit. I'd like to know what's in Pandora's box before I go opening it. Thanks.
Old Dec 29, 2007 | 09:35 AM
John Faughn's Avatar
More info to us may provide more for you , fill in sig = you truck details .
Terms may be off , or different than what I use , lever *** ?
My truck 94 , makes me think of lift pump , but that is separate from the fuel filter , which has a water drain valve /sensor on bottom .
Also I have the fuel prefilter/heater .
Old Dec 29, 2007 | 09:53 AM
crane 1's Avatar
there's a spring and plunger inside it attached to the lever...pretty simple. A little wd40 or oil will keep it from seizing up.
Old Dec 29, 2007 | 10:49 AM
Sorry 'bout dat..........2001 Dodge Ram 5.9 CTD.........it's the lever beside the fuel filter with a drain hose on it. Hope this helps.
Old Jan 3, 2008 | 05:42 PM
Just found out the part number for this is 3923831S from the Cummins Dealer.........the rebuild kit was $8.00 but they changed it and now the kit cost $17.00 Just posted this here for future searchers, save a little time if you have the part number.
Old Sep 9, 2008 | 05:22 PM
82shovel's Avatar
AZ, I sent a PM... where did you go for that part? I'm in Tucson.
MikeThomas
May 21, 2007 12:12 AM
Jeeptug
Apr 11, 2007 11:49 PM
LooseBoltsRob
Jan 17, 2007 07:42 PM
Dodgezilla
Jul 9, 2004 06:17 PM
