hard steering?
Old May 6, 2004 | 06:33 PM
brandon507's Avatar
Question hard steering?
I'm just wondering if anybody else has had this problem.. I have an 02 dodge cdt HO 4x4 and it seems like it is very hard to steer. It doesn't road walk it just seems extremely tight....
Old May 6, 2004 | 10:02 PM
SuperGewl's Avatar
Re: hard steering?
Wrong thread. If yo want help then you may want to post it in the correct YEARS thread
Old May 6, 2004 | 10:20 PM
phox_mulder's Avatar
Re: Re: hard steering?
Done.
And no, no hard steering here.
Assume you checked the PS fluid?
phox
Old May 9, 2004 | 08:47 PM
Mopar1973man's Avatar
Re: Re: Re: hard steering?
Originally posted by phox_mulder
Done.
phox
You might also want to change that power steering fluid... It might be getting dark looking...
Old May 10, 2004 | 04:38 PM
RowJ's Avatar
Brandon507
Assume you are talking at slow speeds, like parking? If so, simple solution is don't turn the wheel unless you are moving at least a little. Power steering can work poorly when foot is on the brake because P.S. uses brake boost pump to augment itself.
Also suck fluid out of your reservoir and replace with new once a week, until it comes out looking like new. 4x4's are hard on PS Fluid. I find PS fluid will turn black in about 5,000 miles if you work your truck hard.
If you are talking about hard steering while driving down the road - I have no idea other than old fluid.
Rowland
Old May 11, 2004 | 10:17 AM
Re: Brandon507
Rowland
I kinda of cheated when I changed it... I pull the return line off the back side of the pump and started the truck and fed it fresh in to the pump until it came out clean... I got some water in mine awhile back and it made it low power in the power steering dept.
If you got to NAPA you can buy power steering fluid for about $10.00 a gallon
Old May 13, 2004 | 08:26 PM
brandon507's Avatar
Im not talking about turning the wheel when im stopped....Im talking about when your driving down the road at any speed....Checked the PS fluid and it looks fine....just wondering if i have a faulty pump.....
Old May 14, 2004 | 02:59 PM
Still change the fluid first then think about the pump... But it is cheaper to change the fluid that changing the pump...
If the fluid gets thin or contaminated it will make the steering hard moving or stopped!
Dargo
Jan 12, 2018 07:45 PM
LUKE-MM-PULLER
Oct 31, 2010 09:35 AM
ocsurf16
Mar 13, 2006 09:24 PM
Palmetto_kid
Mar 26, 2004 11:33 AM
yz
Jul 5, 2003 09:10 PM
