Steering Wheel Replacement?
Old May 1, 2004 | 11:50 AM
edgrim's Avatar
I have a 97 2500 with the two prong wheel and old style cruise control does' anyone know if I can switch to a 98 style, will the wiring work on the cruise and will the splines fit on the hub match? Thanks for any input.eg
Old May 1, 2004 | 03:42 PM
WHIFF's Avatar
My concern would be the airbag. I've thought about replacing my steering wheel. It's the only part on my truck I am not satisfied with. The horns somehow don't work. If I try to press the horn, it gets stuck on and it takes me about 2-3 minutes to get it unstuck, and seems to make everyone around me very angry.
Old May 1, 2004 | 05:30 PM
edgrim's Avatar
Yes mine does also, I forgot about that!! I had to unplug the horns it got so bad
Old May 3, 2004 | 03:10 PM
WHIFF's Avatar
There's got to be a fix for it. The Dodge dealer said "it seemed to work fine" for them! Not being real familiar with the airbag setup, I don't want to screw anything up by trying to fix a stupid horn.
Not to hijack this thread, but does anyone know how to fix this problem?
Old May 8, 2004 | 10:36 AM
Yamadad's Avatar
I too am interested in whether or not this can be done. My steering wheel is trashed (by the previous owner) and I can find a lot of newer style wheels used, but rarely run across the proper one.
Old May 8, 2004 | 10:22 PM
guyssets's Avatar
From: Different City each Week of the Year, Currently: Newtown Ct
airbag
in continuation...
what would the method be in to 'disconnect' the airbag so it doesnt go off when i were to unplug it? yellow plugs = no touch in my time of workin on these.
"they dont call him dumb 'cause he's smart!"
Old May 8, 2004 | 11:52 PM
Yamadad's Avatar
My understanding is that you unhook both batteries and let it sit for an hour or two to let any built up electrical charge dissipate, then you're safe.
I'm sure someone will correct me if my understanding is wrong.
Old May 14, 2004 | 06:59 PM
edgrim's Avatar
Steering Wheel
Just cycle the ignition key several times after unhooking batteries. eg
A-Poc
Aug 23, 2006 08:26 AM
LanceK
13
Jul 14, 2006 08:08 PM
gman07
Jan 28, 2006 03:19 PM
unioncreek
Jun 29, 2005 02:00 PM
