Gas gage not working
Old Nov 13, 2006 | 10:44 PM
Turbonator's Avatar
Gas gauge not working 01 2500 CTD Qcab Shortbox, it works sometimes when down below 1/4 tank of fuel left but other wise just stays on empty. Anyone have any ideas.
Old Nov 13, 2006 | 10:50 PM
wilderness's Avatar
Sending unit in the tank. check the connections on top of the tank for good connection and with the key in the on position check with a meter for voltage. No voltage bad unit. If you have voltage, check the same way but at the gauge. If the same voltage is there then it is the gauge. Oh yea, check all of your fuses first.
Old Nov 13, 2006 | 11:14 PM
J BODY's Avatar
Level unit. About 45 bucks at the dealer and most stock it.....and yes, I lost count of how many I've done.
Old Nov 14, 2006 | 03:47 PM
b.lee's Avatar
my fuel gauge doesnt work either.
would this be the same procedure on my 12v?
Old Nov 14, 2006 | 07:05 PM
dslpower's Avatar
Yep same thing on a 12v. But you could do it like I did. Take it apart, its easy to do. Press out the pivot pin and drill out the housing and pivot arm (its plastic) to 1/8" ( have to hone the pivot arm w/ drill bit slightly) and use a piece of welding rod to make a new pin.
Mine was wobbly on the pin and would'nt make good contact.
This worked for me, not saying it will work on all. Sometimes the resistor array goes bad.
Old Nov 18, 2006 | 01:31 AM
Turbonator's Avatar
I find that the gage moves just ever so little like its stuck or something anyone else find this to happen
Old Nov 25, 2006 | 03:21 PM
Turbonator's Avatar
OK have check all connections and low and behold a simple loose wire has me feeling safe I won't run out of fuel
Old Nov 27, 2006 | 01:18 PM
hamilton71801's Avatar
I wouldn't get too cocky because the sender's are known junk. I put in a new one in my truck and it worked for 1 day and then the same 'ole same 'ole. Now I just use my trip meter and ignore the gauge all together. I really hope you fixed it for good but I would still be leary of it.
Sleigher
May 4, 2017 02:12 PM
ShaneTbolt
Apr 7, 2009 08:22 PM
heykw
Oct 24, 2007 11:53 PM
Scovo1
30
May 11, 2007 01:08 PM
D.B.
Mar 25, 2006 07:06 PM
