Fuel pressure changes when grid heaters cycle?
Old Oct 5, 2010 | 02:11 AM
mstep3's Avatar
Is it normal for the fuel pressure to change slightly when the grid heaters are cycling? I never noticed it happen with the stock fuel pump, but now that I'm running a FASS it changes slightly....It's only about 2psi, but you can tell it drops as the grid heaters clycle on and off. Anybody else notice this?
Old Oct 5, 2010 | 05:41 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Yup, mine does too.
I'm running a Walbro 392 and I see the same.
Those grid heaters are a HUGE amp drain on the electrical system when the cycle on.
Old Oct 5, 2010 | 09:25 AM
Sea:\>Drive's Avatar
Perfectly normal.
Old Oct 5, 2010 | 09:45 AM
infidel's Avatar
More than likely the FP doesn't actually drop.
The gauge reading drops due to low voltage because of the grid draw.
Old Oct 5, 2010 | 10:26 AM
DIESELWRKS's Avatar
ditto
Old Oct 5, 2010 | 10:51 AM
Shovelhead's Avatar
As I am using a mechanical gauge, that's not the case on my truck.
Old Oct 5, 2010 | 06:21 PM
infidel's Avatar
Then my second guess is the low voltage is slowing down the lift pump.
Old Oct 5, 2010 | 08:26 PM
Doj Dewd's Avatar
must be electrical. i have a purely mechanical pump abd see no changes when they kick on/off.
Old Oct 6, 2010 | 12:38 AM
JoeCanuck's Avatar
That's the answer. The voltage drops and it slows down the pump.
Old Oct 6, 2010 | 02:16 PM
Shovelhead's Avatar
BINGO!
Old Oct 6, 2010 | 03:10 PM
mstep3's Avatar
Interesting....I just never noticed this happen when running the stock lift pump....So, you're saying that it's pulling power away from the FASS when the grid heaters cycle on? Does the FASS use more power than the stock pump did? I will have to hook up a mechanical gauge some time & see if it does the same thing as the electronic gauge...
dhughe2
Oct 21, 2010 02:41 AM
Common
Sep 4, 2006 06:08 AM
Silverjay
Jan 30, 2006 02:18 PM
Tate
Jan 23, 2006 09:01 AM
adgr71
Jan 26, 2003 09:25 AM
