fuel gage pegged
Old Feb 16, 2011 | 07:42 PM
leisurlee's Avatar
fuel gage pegged
Filled up Sunday have drove 185 miles and the gage has not moved. I have completed the instrument cluster self test all gages work, checked all connections and swerved the truck back and fourth to see if the float was stuck. Nothing has changed the needle.
any suggestions?
Old Feb 16, 2011 | 10:26 PM
JARHEAD's Avatar
could be a electrical or mechanical failure, but it has happened to me 4 times. I just kept an eye on my odometer, and kept driving. Eventually it dropped back down each time. Possibly the float was ketting stuck on top somehow.
Old Feb 16, 2011 | 11:37 PM
VICIOUS FISHER's Avatar
I agree with jarhead, to address the mechanical try topping off the tank again to bust the float loose (short of dropping the tank). as for electrical a short in the wire to the sending unit (to ground) would produce the same results, check for broken/pinched wire possibly along the frame rail and check continuity of wire. also you need to rule out a faulty gauge. Hopefully you will find an easy fix
Old Feb 17, 2011 | 05:37 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Sometimes the float in the tank sticks.
Try whacking the side / bottom of the tank with a rubber mallet.
Don't hammer on it like you're trying to kill it....... just a couple of light whacks to bump the float arm loose.
Old Feb 17, 2011 | 09:58 AM
infidel's Avatar
What Shovelhead said.
Lying on your back and kicking works too.
From now on only fill your tank to the second automatic shutoff.
Filling to the brim is what causes it to stick.
Old Feb 17, 2011 | 11:14 AM
leisurlee's Avatar
thanks to all, I will try the this and get back.
Old Feb 18, 2011 | 10:55 AM
leisurlee's Avatar
I used a rubber mallet banged on the tank and it fixed the problem.
Old Feb 18, 2011 | 03:35 PM
Tallguy67's Avatar
That is what we call 'percussive maintenance'
cyawallac
Nov 30, 2010 03:26 PM
quadstar
Oct 8, 2010 03:45 PM
babyjoe
May 14, 2009 07:37 PM
38 Cigarette
27
Sep 23, 2008 08:13 AM
Katmandu
Feb 8, 2006 12:25 PM
