Free headlight cleaning!
Old Apr 20, 2010 | 09:14 PM
sheriffav8r's Avatar
My headlights stink. So I bought a cleaning kit for about $10. Then they stunk, but a little less for awhile. Then they stunk the same again. I was watching Trucks! and they showed how to clean your headlights virtually free: Sand your headlights with some wet/dry sandpaper. They used 1500 but I had 600 lying around so I used that. Scrub for 5 minutes. Next, go into your bathroom and borrow the tube of toothpaste. Squirt some on your headlights and polish it with a buffing pad hooked onto your drill. I had an old polishing pad hanging around so I used that. Polish until the paste gets sort of dry and then a little more. Wipe off and clean with glass cleaner. Now my headlights look almost new. Aquafreshtastic!
Old Apr 20, 2010 | 09:56 PM
mstep3's Avatar
i tried one of those headlight cleaning kits that had the sandpaper & sealer with it. Is this the kind of kit you are talking about that you used.
Does the method using the sandpaper & toothpaste work much better?
Old Apr 21, 2010 | 08:33 AM
upersleder's Avatar
whatever you use it helps if you use a good paste wax on them afterwards
Old Apr 21, 2010 | 09:51 AM
infidel's Avatar
An added benefit is it prevents lens cavities too!
Old Apr 21, 2010 | 10:58 AM
SIXSLUG's Avatar
Remember to not use the remaining headlight cleaning kit for toothpaste!
I heard it doesn't work the other way around!
Old Apr 21, 2010 | 11:43 AM
In my opinion, the toothpaste works 100% better and the headlight lens now looks almost new. My drill was running out of juice so I didn't even get to polish it as much as I wanted. I'll never waste my money on a headlight cleaning kit again. Minty fresh, too....
Old Apr 21, 2010 | 01:43 PM
ado2b1's Avatar
That's hilarious! And something I'm going to try this week. I've used a headlight restore kit a couple of times, makes 'em look better, but I'll give the ol' arm n hammer toothpaste a shot. Why not?
Old Apr 21, 2010 | 01:52 PM
AggieJustin's Avatar
Nice find. Sounds like a project to try on my fog lights. The headlights are in good shape since I did the Sport conversion a while back, but the fogs look pretty beat down.
Old Apr 21, 2010 | 07:11 PM
Silver R/T's Avatar
You don't need no stupid kits. Just get some good rubbing compound and if you have a buffer you can make them shine like new
Old Apr 22, 2010 | 12:41 PM
justme-'s Avatar
bingo- all you're doing is polishing, or sanding if bad, the surface of the lens to remove the oxidized plastic. Simichrome polish was the first stuff widely recommended for that before the "kits" started flooding the market.
The sealer kits are a last chance- once you apply the sealer stuff you can;t usually repolish the lens if it goes yellow again later.
Old Apr 22, 2010 | 02:17 PM
Ram95's Avatar
I tried it today and it worked great. One of the lens was pretty bad and it cleaned it right up. Thanks for the post.
Old Apr 22, 2010 | 02:50 PM
high bid's Avatar
Mine have excessive tartar build up any recomendations?
Old Apr 25, 2010 | 01:10 PM
grouch's Avatar
I clean my headlights every month or so with just plain toothpaste. It does fine, it's cheap and they smell kissy sweet afterward.
greenworks
ABDTR #5
Nov 10, 2009 08:03 PM
roysleight
Oct 23, 2006 08:48 PM
Mark Craig
Aug 26, 2005 07:57 AM
Mark Craig
Aug 25, 2005 04:22 PM
