font end-AGAIN
Old Apr 2, 2009 | 09:39 AM
smokeyram's Avatar
font end-AGAIN
I am so tired of this dodge front end, im sure others are equally exausted.
Ive replaced just about every thing on the font end, with exception of the steering box and steering shaft.
Now, not only is my shudder back, its not as bad as a death wobble, but still aggrivating.
But its only when im on the brakes. the steering wheel pulls back and forth, almost feels like a bump steer, but only when braking .
So once again, ill need to lay down, have someone else move the wheel, but whats up with it, what should i be looking for?
Old Apr 2, 2009 | 01:01 PM
MDMIKE's Avatar
May sound stupid, but make sure you didn't end up with a "pig tail" in your brake line when you re-installed one of the calipers. If the line has a twist in it, you could have a pull to one side. Don't rule out the rear brakes causing the pull either. Make sure you don't have a wheel cylinder or axle seal leaking and causing the rear to hang up a little.
MIke
Old Apr 2, 2009 | 01:51 PM
Wild4kst8's Avatar
shudder is generally a sign of warped rotors
Old Apr 2, 2009 | 08:36 PM
Bluedually4x4's Avatar
That is what I was thinking, warped rotors
Old Apr 3, 2009 | 01:26 PM
Junk Man's Avatar
Warped rotors are caused by sticking calipers. Sticking calipers could be caused by dirty/corroded slides, faulty caliper or rubber brake line expanding.
Old Apr 5, 2009 | 12:50 PM
SIXSLUG's Avatar
Shudder sounds like warped rotors to me, too. Driven thru any deep puddles after braking hard lately? Just my .02!
Kurt
daboocru
Dec 5, 2010 06:22 PM
markm4
Sep 25, 2008 07:49 AM
belfert
Sep 2, 2005 02:18 PM
dieselcrazy
Sep 12, 2004 08:44 PM
Scotty
Jan 9, 2003 10:31 AM
