Fog Lights Out
Old Mar 22, 2006 | 09:48 AM
cville6's Avatar
Fog Lights Out
On the return trip from KY on Sunday I noticed the green fog light indicator wasn't on. Stopped the truck to check and sure enough no fog lights. Checked the fuse but haven't checked the lamps (too much snow on the ground to crawl around under the truck). Just doesn't seem that both lamps would go at once. Is there a relay for the fog lights? Where?Could it be the push pull part of the headlight switch?
Old Mar 22, 2006 | 10:08 AM
6WHEELER's Avatar
mine was the switch, a couple of yrs ago, don't know if there is a relay will have to look.
Old Mar 22, 2006 | 11:01 AM
BlueRam01's Avatar
There is a relay in the PDC.
Old Apr 17, 2006 | 07:49 AM
cville6's Avatar
It's the switch!
Finally had time to get the truck in the garage and check out the fog light problem. It is the little contacts in the push-pull part of the headlight switch. I have found the non-foglight type of headlight switches listed at NAPA and Advance Auto parts for $60+. Is the foglight version of the switch a dealer only part? any idea what it will cost?
Old Apr 19, 2006 | 07:42 AM
cville6's Avatar
I figured the factory switch was too much money so I just tapped the foglight wires and wired a cool little rocker switch on the corner of the dash to fire up the fog lights. Five bucks for the switch and now I can turn on the fog lights independent of the head lights and use them for "day time running lights".
Old Aug 22, 2006 | 03:59 PM
graycenphil's Avatar
I've got the same problem. Which wires run the foglights?
Old Aug 23, 2006 | 10:45 AM
cville6's Avatar
Sorry, it's been so long since I was in that part of the dash I couldn't tell you which are the fog light wires. But all I did was just unplug the connector and test till I found the right one.
bullboy85
Dec 18, 2009 12:55 PM
fjbiker86
37
Dec 9, 2007 07:29 AM
patriot dodge
Nov 23, 2007 07:57 PM
Mcmopar
71
Feb 27, 2007 01:58 PM
msatow
Sep 27, 2006 07:32 PM
