Fog light help
mine too...
Mine is doing this too! Worked up until a week ago, then would flicker a bit now nothing. This is a new switch (6 months) and I've got the spare old one, both nothing. I'm a little leary of buying a new one as there's no return at the dealership if it's not the problem. Both fuse and relay are good.
The dash switch energizes a relay which opens and closes the Ground side of the lights. If you pull the relay from the socket, you can short the "normally open" pins on the relay socket with a piece of wire and manually activate the fogs. On mine, they're the 2 large tabs; the other 4 tabs are smaller and are oriented 90 degrees. There should be a schematic on the sde of the relay. From the socket, you can also test the dash switch circuit using a meter.
FIXED MINE!!
Trace the harness from the bulb at the fog light itself to the 2-pin connector underneath behind the bumper. The connector itself even though it looked OK was loose and not connecting inside. Pushed it back together and all is good. Seems silly in hindsight but it's not exactly easy to find and can be easily overlooked as the connector seemed ok and I actually had voltage on both pins at the bulb, telling me I had power but maybe a short. Turns out only 1 pin of the 2 pin connector was loose and that was the switched ground wire. Hope this helps.
Re: mine too...
fade94
Sep 15, 2009 12:53 AM
fjbiker86
37
Dec 9, 2007 07:29 AM
MaroonCumminsInOre
Sep 21, 2004 07:35 AM
KansasMan
Aug 25, 2004 08:30 AM
