Finally found a clean 12v.. 34" tires and no lift?
Old 05-23-2018, 05:52 AM
rebar's Avatar
Hey everyone.
Ive been searching for a clean 12v and may have found it. It almost to clean for me and the wrong 4.10 gears, but its only one hour drive so I better consider it.
My question is, can I remove the 4in/3in leveling kit on this truck to lower it enough for my 79" garage door and not rub front fenders with 34" tires on offset rims? Because I don't want to lower the gearing even more with smaller tires..
Thanks!
Attached Thumbnails Finally found a clean 12v..  34" tires and no lift?-12valve.jpg
Old 05-23-2018, 07:04 AM
Received 2,392 Likes on 1,576 Posts
Those wide rims pictured and 34 inch tires will almost be guaranteed to not fit on a stock height truck...Unless you can get away with never turning the front tires for a turn.
Real options as I see it would be:
Don't park it in the garage.
Smaller tires and no lift, which will make it rev high on the highway
Swap axles for 3.54s then lower it and buy new tires / rims
Find a different truck.
Install bigger garage door.
Danderson (06-18-2018)
Old 05-23-2018, 10:56 AM
rebar's Avatar
Those tires and rims rubbed BAD the way it sits now!
Crappy repaint with runs and bugs.
Brakes pulled hard to left.
Trans shifted hard
Rust
Doors didn't close tight..
Big hole in bed from stacks
I was disappointed.
https://cedarrapids.craigslist.org/c...573589888.html
Old 06-18-2018, 04:09 AM
glmoore0001's Avatar
Trans shifted hard
Rust
I was disappointed.
Yeah, you just do not know till you get there. I bought a 24v on the west coast. Gave 16,500 for it. Probably have 20K in it now, making it right again.
Old 06-18-2018, 09:57 PM
torquefan's Avatar
Trans shifted hard
Rust
I was disappointed.
Too bad, the picture sure looks good. That aftermarket grille looks kinda interesting, I wonder where it's from.
05-29-2009 10:24 PM
checkster
01-02-2008 02:35 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
sakisaki400
23
12-31-2006 10:17 PM
Quick Reply: Finally found a clean 12v.. 34" tires and no lift?
