Finally found a clean 12v.. 34" tires and no lift?
1 Attachment(s)
Hey everyone.
Ive been searching for a clean 12v and may have found it. It almost to clean for me and the wrong 4.10 gears, but its only one hour drive so I better consider it. My question is, can I remove the 4in/3in leveling kit on this truck to lower it enough for my 79" garage door and not rub front fenders with 34" tires on offset rims? Because I don't want to lower the gearing even more with smaller tires.. Thanks! |
Those wide rims pictured and 34 inch tires will almost be guaranteed to not fit on a stock height truck...Unless you can get away with never turning the front tires for a turn.
Real options as I see it would be: Don't park it in the garage. Smaller tires and no lift, which will make it rev high on the highway Swap axles for 3.54s then lower it and buy new tires / rims Find a different truck. Install bigger garage door. |
(Post 3348654)
Real options as I see it would be: Don't park it in the garage. Smaller tires and no lift, which will make it rev high on the highway Swap axles for 3.54s then lower it and buy new tires / rims Find a different truck. Install bigger garage door. Those tires and rims rubbed BAD the way it sits now! Crappy repaint with runs and bugs. Brakes pulled hard to left. Trans shifted hard Rust Doors didn't close tight.. Big hole in bed from stacks I was disappointed. https://cedarrapids.craigslist.org/c...573589888.html |
Originally Posted by rebar
(Post 3348662)
(Post 3348662)
