Finally found a clean 12v.. 34" tires and no lift? - Dodge Diesel - Diesel Truck Resource Forums
Old 05-23-2018, 06:52 AM
Hey everyone.
Ive been searching for a clean 12v and may have found it. It almost to clean for me and the wrong 4.10 gears, but its only one hour drive so I better consider it.
My question is, can I remove the 4in/3in leveling kit on this truck to lower it enough for my 79" garage door and not rub front fenders with 34" tires on offset rims? Because I don't want to lower the gearing even more with smaller tires..
Thanks!
Attached Thumbnails Finally found a clean 12v..  34" tires and no lift?-12valve.jpg
rebar is offline
Old 05-23-2018, 08:04 AM
Those wide rims pictured and 34 inch tires will almost be guaranteed to not fit on a stock height truck...Unless you can get away with never turning the front tires for a turn.
Real options as I see it would be:
Don't park it in the garage.
Smaller tires and no lift, which will make it rev high on the highway
Swap axles for 3.54s then lower it and buy new tires / rims
Find a different truck.
Install bigger garage door.
oliver foster is online now
The Following User Says Thank You to oliver foster For This Useful Post:
Danderson (06-18-2018)
Old 05-23-2018, 11:56 AM
Those tires and rims rubbed BAD the way it sits now!
Crappy repaint with runs and bugs.
Brakes pulled hard to left.
Trans shifted hard
Rust
Doors didn't close tight..
Big hole in bed from stacks
I was disappointed.
https://cedarrapids.craigslist.org/c...573589888.html
rebar is offline
Old 06-18-2018, 05:09 AM
Trans shifted hard
Rust
I was disappointed.
Yeah, you just do not know till you get there. I bought a 24v on the west coast. Gave 16,500 for it. Probably have 20K in it now, making it right again.
glmoore0001 is offline
Old 06-18-2018, 10:57 PM
torquefan's Avatar
Trans shifted hard
Rust
I was disappointed.
Too bad, the picture sure looks good. That aftermarket grille looks kinda interesting, I wonder where it's from.
torquefan is offline
05-29-2009 11:24 PM
checkster
01-02-2008 03:35 PM
PEAKSTRYDE
10-11-2007 05:20 PM
VikingDiesel
47
05-11-2007 01:52 AM
sakisaki400
23
12-31-2006 11:17 PM
Quick Reply: Finally found a clean 12v.. 34" tires and no lift?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
