Few issues on a 97
Old Aug 17, 2009 | 10:21 PM
TRCM's Avatar
Few issues on a 97
Have a few issues, and would like an idea of where to start.
1) the cruise decided to stop working
2) the blower motor sometimes works, sometimes don't. Seems like it will start up on it's own if you leave it in the on positon. Also seems to blow a lot less than it use to
3) engine is very hard to start most of the time if it hasn't been driven in a good while
Old Aug 18, 2009 | 07:55 AM
patdaly's Avatar
1.) Cruise light on the wheel come on? If so, check your vacuum system clsoe.
2.) Replace the Blower motor, common and easy to do.
3.) Probably a small crack in the rubber hoses of the fuel system, try priming it until the overflow valve sings and see if it starts right up. If it does, theres your answer, replace all the rubber.
Old Aug 18, 2009 | 06:05 PM
TRCM's Avatar
1) yes, light does come on
2) figured as much
3) all rubber was replaced ~ 2 yrs ago
Old Aug 18, 2009 | 10:43 PM
rebal's Avatar
the filter drain is a common spot to let air in it wont leak fuel but when it cools off it will let air in to the filter Or it could be bad o rings at the strainer /fuel heater
Scat
Feb 27, 2012 12:12 PM
bansh-eman
15
Sep 21, 2009 11:11 AM
STACKED
Jun 10, 2009 10:54 PM
iker42
Jun 22, 2008 07:29 PM
GoodoleBob
Sep 27, 2006 11:37 PM
