fan switch
Old Jan 31, 2011 | 09:24 AM
csa's Avatar
csa
fan switch
hey guys need help....my 01 has a 4 speed fan switch that only works in high mod, just started. is this an elec switch or vacum cuz i know i have a vacum leak some where cuz the ac works ify...goes back and forth from def to vents deppending on rpms.
Old Jan 31, 2011 | 09:29 AM
blackimpala's Avatar
I have a 96 so I may not know what I am talking about. After your switch there is a multi-speed resistor,easy to get to, when it gos bad all you will have is high speed. Cheap fix from NAPA.
Floyd
Old Jan 31, 2011 | 09:52 AM
swordfish's Avatar
Blackimpala is correct. I have replace mine a couple times now. The resistor screws into an area near the fan and has a plug that plugs into it. When you pull yours out it will probably be either cracked or the connections broken. Stubby phillips head comes in handy. Good luck
swordfish
Old Jan 31, 2011 | 10:15 AM
csa's Avatar
csa
thanks i will try that
Old Feb 1, 2011 | 09:33 AM
Swordfish, if you have to keep changing the fan resistor maybe your fan is going bad and is putting a higher load on the resistor.
Floyd
Old Feb 1, 2011 | 09:50 AM
swordfish's Avatar
Thanks for the heads up floyd. I did just that after the second resistor blew in a 2 week period. Replaced the fan and the resistor has been good for about 2 months now.
swordfish
Old Feb 1, 2011 | 04:05 PM
Busboy's Avatar
All good info on the fan resistor for the fan speeds however you must also have a vacuum leak as the modes are vacuum actuated with a fail safe to def. If vacuum bleeds off it will default to def. If the lines look ok up on the drivers firewall check for a rotted line under the drivers battery.
Old Feb 1, 2011 | 07:33 PM
csa's Avatar
csa
it only goes to def. under high rpms and ac only .... was going to do res. today but it was -44 wind chill screw that.. 50 on friday i think it can wait
Old Jun 16, 2011 | 12:13 AM
amandrew325's Avatar
Just got the email notification today. Must be a common thing. done a replacement many times in my dodge. It actually does not work at any speed. The rear control **** works fine at all speeds but the front does nothing.why don't you call on the dealer, give the part number and ask for a possible solution.
_______________________________________________
Standard fan switch
Old Jun 16, 2011 | 12:42 PM
Tejas TJ's Avatar
I had the same problem with my truck since I have owned it. I pulled my fan out and dust and mud fell out. The resistor also crumbled into pieces due to the bad fan causing a greater draw on the resistor. Check those parts and get back to us.
Old Jun 16, 2011 | 07:54 PM
Thanks for sharing your thoughts man...i'm gonna check it now
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
