Factory CD player clock too dim
Old Mar 26, 2008 | 03:47 PM
CORed's Avatar
My factory CD player clock seems to have burned a bulb. It was sure brighter before. With or without the lights on, it's the same. Can't hardly even see it in the daytime now. When I turn the lights on and set the dimmer setting one notch down, its impossible during the day and hard to see at night even. The odometer is brighter and they use to both be the same.
Can a bulb in the CD player burn out? All other functions on the player seem to be lit up as normal. But the main band/clock/cd track readout is dimmer.
Has anyone ever experienced this? Can it be fixed easy? I don't really want a new head unit... yet.
Old Mar 26, 2008 | 04:22 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Just rebuilt on of those animals a week ago.There are small replacement lights behind the PCB board.First take the front face off.Yours being a newer model,it should have 3 small screws on the PCB.The bulbs are held by turning the bulb using a flat head screw driver to remove them.I have to replace a couple of bulbs on mine.
Old Mar 27, 2008 | 08:42 AM
CORed's Avatar
Thanks Dave, can you get the bulbs at a common radio shack if you bring the old ones in?
I'll give it a shot as you describe and report back if I have any problems.
Old Mar 27, 2008 | 10:03 AM
I haven't look yet for the bulbs.You should be able to get these bulbs at the electronic shops.I'm going to check here this weekend...
89dieselkong
Nov 11, 2010 06:35 PM
danalex
Dec 27, 2007 01:39 PM
underwoodtransp
Apr 20, 2005 07:36 PM
cah
May 28, 2003 09:30 AM
