Emergency Brake
Old Sep 18, 2007 | 08:01 PM
paparcl's Avatar
Emergency Brake
My emergency brake is down to floor and will not hold. I see there is an adjustment for the cable but is there another adjustment on each rear wheel. I have disc brakes all the way around. Do you have to remove the rear wheels or do you go thru the backing plate like the old drum types? Also how do you get the wrench on the cable adjustment, I can't get a hold of the nut! I have about 50% rear brakes left.
Old Sep 18, 2007 | 08:09 PM
phox_mulder's Avatar
Parking Brake (they don't call them emergency brakes anymore) is seperate from the disc brakes.
It's a little drum brake on the back of the disc, and is adjusted through the access hole like old style drum brakes.
Since it's going to the floor, I'd guess there's something else going on, as they don't usually wear out unless you've done a lot of driving with the parking brake engaged.
phox
Old Sep 18, 2007 | 08:19 PM
paparcl's Avatar
Parking Brake
Thanks phox. I guess calling it the "emergency brake" is showing my age!
I will get under it and check it out.
bulldog_bones
Sep 9, 2009 01:53 PM
fitzer
20
Jul 28, 2003 07:33 AM
Marine
May 18, 2003 11:14 AM
joemikey
Oct 10, 2002 11:39 PM
