emergency brake adjust
Old Jul 23, 2003 | 05:48 PM
js's Avatar
js
Re:emergency brake adjust
sounds to me like you should set up the rear brakes and you will have emerg. brake again
Old Jul 23, 2003 | 06:03 PM
Dieseldude4x4's Avatar
If memory serves me right, which may not be, when you tighten the one screw, it adjusts both brakes by shortening the overall length of the cable since it pulls equally on both sides.
Old Jul 23, 2003 | 07:02 PM
Still sounds like the basic concept is the same, by tightening the nut, you effectively shorten the overall cable length thus tightening both brakes.<br><br>Can you post a pic of the adjuster?
Old Jul 23, 2003 | 11:10 PM
ARAcummins's Avatar
Well let us all know cause I need to tighten mine too, it won't hardly hold my truck empty. I think you are right one only tighting one side, I crawled under the other day to do it and looked at it and was baffeled , can't make any sense of that goofy setup.<br>Heath
Old Jul 24, 2003 | 06:58 AM
jfpointer's Avatar
'02 FSM says:<br><br>CABLE TENSIONER<br>ADJUSTMENTS<br>ADJUSTMENT<br>NOTE: Tensioner adjustment is only necessary when the tensioner, or a cable has been replaced or disconnected for service. When adjustment is necessary, perform adjustment only as described in the following procedure. This is necessary to avoid faulty park brake operation.<br><br>They refer to it as a &quot;drum in hat&quot; design. There's a set of shoes inside the rotor, it looks like, with what appears to be a pretty normal looking star wheel adjuster for the parking brakes. I haven't crawled under mine to look, but from the picture it looks like you might have to take the wheels off to get access from the back to adjust it.
Old Jul 24, 2003 | 07:19 AM
redramnc's Avatar
If it is a drum in disk design then, as the brake cable pulls one side tight, the balancing bar on the cable will then stop, pivot slightly, and continue to pull the other side until tight. Once one side is tight then it cannot be pulled farther and the cable pulls against the center attachment and the lever action pulls the other side.<br><br>All of this is subject to the EB shoes being properly adjusted inside the disk.<br><br>Or I could be mistaken.
Old Jul 24, 2003 | 08:13 AM
jfpointer's Avatar
[quote author=redramnc link=board=5;threadid=17449;start=0#163530 date=1059049180]<br>If it is a drum in disk design then, as the brake cable pulls one side tight, the balancing bar on the cable will then stop, pivot slightly, and continue to pull the other side until tight. Once one side is tight then it cannot be pulled farther and the cable pulls against the center attachment and the lever action pulls the other side.<br><br>All of this is subject to the EB shoes being properly adjusted inside the disk.<br><br>Or I could be mistaken.<br>[/quote]<br><br>From the diagrams, that sounds about right. It looks like the only real adjustment is on the litttle parking brake shoes.
Old Jul 24, 2003 | 10:21 AM
towin1JT's Avatar
When you run out of adjustment for E-brake, it's time to replace the rear brake shoes. That solved my problems on my '97 when it had ~115k miles and had never had new shoes.<br><br>John
Old Jul 24, 2003 | 08:00 PM
silverram323's Avatar
Hey when you guys figure this out i want to know also. I took a pic for you dieseldude4x4.<br><br>Kev
Old Jul 24, 2003 | 11:55 PM
Haulin_in_Dixie's Avatar
My brakes did not function well from new. I finally gave in and fixed it the &quot;half fast&quot; method. For $1.43 I bought a cable shortener from Walmart and put it on, took at least five minutes and have not had a problem since then. That was a year and a half ago. Used to us them on the old cars and it works as well on the CTD.
Old Jul 25, 2003 | 03:47 PM
jfpointer's Avatar
[quote author=Haulin in Dixie link=board=5;threadid=17449;start=0#163930 date=1059108907]<br>My brakes did not function well from new. I finally gave in and fixed it the &quot;half fast&quot; method. For $1.43 I bought a cable shortener from Walmart and put it on, took at least five minutes and have not had a problem since then. That was a year and a half ago. Used to us them on the old cars and it works as well on the CTD.<br>[/quote]<br><br>Do you have four wheel discs? I'm sure the setup is different on trucks with rear drums.
