Daytime Run Lights
Old Apr 25, 2011 | 06:17 PM
Cholmes's Avatar
Daytime Run Lights
Hi, I have noticed my DRL have all the sudden quit, I have checked the fuses and can't even find a fuse for them. Is there something else it could be? Emergency is all the way out, It is an 02 Ram 2500 5.9
Old Apr 27, 2011 | 08:14 AM
nickg's Avatar
DRL well known to fail, usually they stick on and cant shut the lights off.
headlights will work normally if its unplugged, except that the hi-beam indicator wont work, it can be jumpered at the drl to restore the hi-beam indicator light function.
mine has been unplugged and a Daniel Stern Parklight DRL installed. Daniel's DRL was 40$
here is a pin out of the DRL, it will help you fiqure out if the DRL is indeed failed
my opinion is the parklight DRL is far superior, I can now "flash my headlights if needed, it saves on headlights, and the Park light version looks better(and its legal in canada)
looks like this
and with parklights only on look like this
Old Apr 27, 2011 | 08:17 AM
Cholmes's Avatar
Something to consider, My high beam indicator still works so does that mean that it is not the DRL? Or does the high beam In. only not work when the thing is unplugged?
Old Apr 27, 2011 | 09:59 PM
nickg's Avatar
indicator working is no indication of moduel being good or bad, I was just saying if you unplug it the indicator wont work unless you jumper the pins 3 and 6. but with the pin out(diagram) you can get a test light and see if the module is sending voltage to the lites, if its not then its a bad module
Old Apr 28, 2011 | 05:30 AM
Cholmes's Avatar
OK Great, thanks for the info. I will check it to see if it is bad. Where can I get the one for the park lights if needed?
Old Apr 29, 2011 | 07:46 AM
nickg's Avatar
just google daniel stern, the web page not really set up that well and you have to dig around but there is tons of good info in there
http://www.danielsternlighting.com/p.../products.html
BuckyKatt
Feb 8, 2013 01:12 PM
getrdun
Nov 26, 2008 11:46 AM
Badd Dogg Guy19
Apr 28, 2005 03:36 PM
blownbanana
30
Mar 28, 2004 12:41 PM
fitzer
Jan 18, 2003 01:11 AM
