cruise control help
Old Oct 21, 2008 | 02:41 PM
Big Deezul's Avatar
cruise control help
my cruise stopped working in my 97...any ideas where to start looking to fix this?
Old Oct 21, 2008 | 03:05 PM
Busboy's Avatar
First look for a vacuum line off under the hood......... close to the firewall drivers side is common. Then check your brake lite sw. It has 6 contacts, 2 for the brake lites and 4 for the cruise. The sw are known problems.
Old Oct 21, 2008 | 06:43 PM
infidel's Avatar
Most common cause of failure is battery acid rotted vacuum line or wiring under the driver's side battery.
Second is bad brake light switch. Test by lifting the brake pedal and seeing if the cruise will work.
Replacement switch is $13 from Napa.
Old Oct 21, 2008 | 07:00 PM
2500's Avatar
another vote for vacuum leak.. mine quit working... problem was a vacuum hose knocked lose when I adjusted my valves.
Old Oct 21, 2008 | 07:18 PM
johnh's Avatar
first is fuse..........
Old Oct 21, 2008 | 09:05 PM
Big Deezul's Avatar
Thanks for the help guys...I will check these out this weekend and give an update
Old Oct 22, 2008 | 07:30 AM
kyncl's Avatar
my dad has a 98 12v and his cruise works for a while. After you stop and try to use the cruise again it wont work. I will work the next day. Any ideas on this problem?
Old Oct 22, 2008 | 11:24 AM
Busboy's Avatar
That goes without saying
As for the 98
"my dad has a 98 12v and his cruise works for a while. After you stop and try to use the cruise again it wont work. I will work the next day. Any ideas on this problem?"
I would throw a brake lite SW at it, they are so cheap (and cheaply made) I took one apart one time to find out why there is so much trouble with them. The contacts inside are very small and rounded so all you need is a small amount of build up on them and they fail.
Old Nov 9, 2008 | 02:07 PM
Jvenne86's Avatar
when i set my cruise it doesnt come on but the windsheild wipers do come on. any i deas what causes that?
Old Nov 9, 2008 | 03:26 PM
infidel's Avatar
Sounds like some wires are bared and shorting together under the steering column cover.
I'd take care of it soon before something dangerous happens like your headlights start turning off and on with the blinkers.
Old Nov 9, 2008 | 05:42 PM
CarlJensen's Avatar
My CC solenoid and wires under the driver battery both had holes eaten through them! That battery can do a LOT of damage!!
Old Nov 9, 2008 | 09:31 PM
Jvenne86's Avatar
thanks for the input. i will be checking both of them this week
Old Nov 24, 2008 | 08:27 PM
Big Deezul's Avatar
tried the brake light switch....didnt fix it...tomorrow I check under the drivers battery
Old Nov 25, 2008 | 05:34 PM
atc250r's Avatar
Does the light in the switch come on when you push the power button? If it does then I'm going to assume that when you hit the button to set the cruise it just doesn't set? Mine doesn't work either, it turns on the light in the switch but nothing else works. Then, when I try to shut it off, the light usually won't go off. I've checked the common stuff like people are telling you to do but if that doesn't fix it I'd guess the "clockspring" or whatever Dodge calls in behind the steering wheel is taking a dump.
John
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
Big Rich
Feb 22, 2004 08:31 AM
Resident13
Jan 3, 2004 01:15 PM
TexasDiesel
Dec 27, 2002 10:47 AM
