Component failure mileage.
Old Aug 3, 2005 | 06:14 PM
Bart M.'s Avatar
I own a 1999 Dodge 2500 Cummins 4 X 4 with 5 speed maual transmission. It has approx. 200,000 miles on it. I am looking for experience of other Cummins owners concerning the anticipated mileage failure point for the following five components:
Starter
Alternator
Water Pump
Front Wheel Bearings
Air Conditioner Compressor
I anticipate having to take many long range trips in this truck in the coming months and am trying to head off problems on the road with needed replacements beforehand.
Thanks for your help.
Old Aug 3, 2005 | 07:01 PM
cmckinney's Avatar
Don't know about the above parts but do know the VP44 injection pump and the lift pump will go out. The rest is pretty much bullet proof.
-CM
Geico266's Avatar
Starter: You should replace the starter contacts ASAP. http://www.fostertruck.com/dodge/default.htm See my pics. Easy job.
I would have the front end checked for ball joint replacement.
A fuel pressure guage is a MUST!
Old Aug 3, 2005 | 10:29 PM
Tiny's Avatar
Ball joints at 57K
Track bar at 57K
LP at 93K
High pressure power steering line 99K
Starter at 109K
Vp44 at 125K
Hopefully I have covered all the expensive stuff, this truck will hopefully run 350K miles, so I haev many years to keep it on the road.
Old Aug 3, 2005 | 10:49 PM
tool's Avatar
Ball joints 110 K
Track bar 142 K
Front wheel bearings, 130 K
clutch 147 K
Old Aug 4, 2005 | 12:17 AM
J BODY's Avatar
I'm at 80K. Here's my score card:
Ball joints: original
track bar: original (and minimal play I might add)
front wheel bearings: original
torque convertor: 1st at 26K right after I bought it, 2nd still going.
lift pump: original (still at 13psi plus and never drops below 9)
VP: replaced my first one last week. 80K
Injection pumps go whenever they want. I've seen them go 300K+, I've seen them go in less than 20.
Old Aug 4, 2005 | 07:53 AM
Mopar1973man's Avatar
65K and here is my failure listing...
Front Driveshaft
1 Lift Pump
1 VP44 Injection Pump
Thermostat
Not bad for 65K...
Old Aug 4, 2005 | 01:14 PM
Geico266's Avatar
Drive it like you stole it.
Old Aug 8, 2005 | 10:59 AM
durasmack's Avatar
has anyone ever figured out how to put a P7100 on a 24 valve?
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
ppsi
Jan 27, 2004 12:54 PM
dodgedude361
Dec 28, 2003 03:36 PM
BigBlue
15
Mar 19, 2003 03:14 PM
