Cab clearance lights and fog lights
Old Nov 14, 2005 | 10:13 PM
  #61
d0dg301's Avatar
AggiePhil, That was a very well written and detailed article. I found it very helpful in my decision on installing a set of these on my truck. I printed out your article and will use it for a reference. Thanks
Old Nov 15, 2005 | 10:37 AM
  #62
ridofpwrstroke's Avatar
Originally Posted by Eskimo
Plus, I don't ever want to have to replace another bulb.. silly-cone up there real well to seal 'em, and be done once and for all..
I didnt use any silicone on both trucks and never had a leaky light. I also never had to change a bulb. If I did, it would take about 1 minute to get up on the roof, 15 seconds to remove screws, 10 seconds to replace bulb, 15 seconds to put screws back in, 5 minutes to get back down. Its not that hard. That is after consuming a few drinks and doing it in the cold with ice on the ground with a 40lb backpack strapped to me and the ole lady yelling at me.
Old Nov 15, 2005 | 10:48 AM
  #63
jfpointer's Avatar
I'd pick a different time, if it were me... Then again, finding a time when the ole lady isn't yelling at me might be tough.
Old Nov 15, 2005 | 11:41 AM
  #64
Eskimo's Avatar
Who said it was hard? Not I. Let me explain how things are on my 1998, 245,000 mile truck, which spent much of its life baking in Texas.
1 minute to get screwdriver and get on roof.
15 seconds to remove screws, noticing that the plastic gasket under the screw head how now disintegrated.
30 seconds to gently pry the clearance light off the roof as not to tear the seal to heck.
15 seconds to change the bulb.
15 seconds to re-install now less sealing screws.
(Fast forward to after a rainstorm)
5 seconds to notice something odd.
15 seconds to get on the roof and notice the light has condensation inside it
5-10 minutes looking for something to replace that *&(*&$ little gasket that disintegrated, to no avail.
See where I'm going with this?
You've said you never had to change a bulb. I've changed 3. While they don't leak water into the cab, guess which ones have condensation in them? Yup.
No seal lasts forever, but clear silicone can be your friend.. right until you need to remove the light.
Old Nov 17, 2005 | 07:39 PM
  #65
BoostdCTD's Avatar
Originally Posted by Stamey
Yeah, but we (well I) are trying to address the problem some trucks have of melting the headlight switch. This makes LEDs a legitimate consideration since they draw significantly less power.
Chris
I found LEDs somewhat appealing but to help alleviate the switch problem I paid $20 for a headlight rewire kit from Summit racing (was on clearance) which takes the headlights right off the circuit. So now all my headlight switch does is dim my gauges and run my parking lights. Can't buy many LED lights for $20, but there is the brightness/ longivity factor there too.
Old Nov 20, 2005 | 10:33 AM
  #66
Patrick Campbell's Avatar
Does anyone know if the older style lights will fit on a newer truck?
Old Nov 20, 2005 | 11:08 AM
  #67
DodgeCowboy's Avatar
DTR's Cow Boss
i at one time was goin to put 01 cab lights on my 96 they were goin to work just fine what you have to look close at is the roll on the front of the cab i think every thing from 94 to 01 is fine maybe the o2s allso i know the third gens are out of the question diff cab
Old Feb 24, 2007 | 06:12 AM
  #68
gies's Avatar
Originally Posted by Mcmopar
ALL 1998's had the old style lights, I have one with the factory installed setup. I believe it was 2001 when they changed!!
So if I wanted to put on the lights and have it look like it would have come off the line in 1998.5 these would be the lights?
Thanks for the help,
Old Feb 24, 2007 | 07:11 AM
  #69
BoostdCTD's Avatar
Those look about right.
Here is what mine look like... in clear, which only works for a few colors.
They have chrome covered amber bulbs but the color isn't consistent, I'd recommend going straight to LED. I actually have some but haven't installed them yet.
Old Feb 24, 2007 | 08:49 PM
  #70
can17's Avatar
Those lights in the link look like the low profile lights. My brother-in-law's 98.5 3500 has the older "triangle" shaped lights.
Old Feb 27, 2007 | 11:28 AM
  #71
simadownow6988's Avatar
just got off the phone with my dealer. awsome price on the light kit, but for them to do it requires a few limbs. 340.00 to install! ouch! I guess I wont be having clearance lights.
Old Feb 27, 2007 | 01:58 PM
  #72
dhughe2's Avatar
BoostCTD, i like that look! I have a champagne colored vehicle and i was thinking the shaded lights would look pretty good on it.
fjbiker86
37
Dec 9, 2007 07:29 AM
Ramcam
Apr 7, 2007 03:43 PM
ecaff
Feb 14, 2006 07:38 PM
cummins dsl
22
Jun 27, 2005 11:53 AM
Nov 23, 2002 07:35 PM
