busted mirror, need help
Old Dec 26, 2004 | 10:30 PM
4doogie's Avatar
Well let someone drive the truck and they managed to hit the mirror, errrrrrr the thing is it didnt break, but the mirror now swings freely, has anyone had this happen, is there anyway to ix it or am i looking at buying a whole new mirror?
Old Dec 27, 2004 | 02:53 PM
kandgo's Avatar
Take the mirror off and you will see three small screws that hold a triangular piece of plastic which is a cover,under that cover there is a tightning set screw that you can tighten. The mirror comes off easly, the door mount is held on with two screws one by the mirror head and one by the door handle, you will more than likley need to go to the local parts store and pickup some new plastic door panel snap in holders you do not have to take it completley off just unsnap the top and one or two down the hing side, it takes a 10mm socket to get the mirror off,be sure and stuff a towel down in the door panel and to unclip the elect plug if yours are powerd. On that set screw you might have to turn over the little aluminum piece that creates the friction when going back with it. Goodluck,,Rick
Old Dec 27, 2004 | 06:48 PM
DustyRock's Avatar
When I got my truck both mirrors flopped in the breeze. Tore into them and found the screws that hold the clamp (the one that goes around the main mirror post) screw into pot aluminum and the threads were stripped on both mirrors. They are metric but I tapped them to 1/4-20 and used cap screws. Works great. I do not know what caused the problem initially but suspect the kids were using them for a swing set.
Old Dec 27, 2004 | 07:45 PM
4doogie's Avatar
cool thanks guys, sounds like another " when I have time things"
Patrick Campbell
Oct 24, 2005 08:33 PM
CCOUGHRAN
Mar 31, 2005 07:47 PM
lawnman757
Mar 16, 2005 06:23 PM
rjweiss
May 4, 2004 08:51 AM
damon_achey
Jul 30, 2003 06:02 PM
