Brakes kicking out? ABS?
When I'm coming to a stop, my brakes work as normal. Then, when I get below 4mph or so, suddenly the pedal pushes back, like ABS is kicking in, and my brakes are gone!
A hard stomp on the pedal stops the truck.
I'm nearly certain that the ABS is causing this, as my CB radio makes a noise each time this happens; it makes a noise whenever the power windows are operated, for example. So some servo on the ABS is kicking in.
The question is, why? And more importantly, how do I fix it?
Michael
Michael
check your wheel bearings I had a bearing go bad and a small piece of metal got stuck on the sensor and caused that on my 01. After I found the metal I looked at were it came from.
myshorts
17
Jan 11, 2008 03:48 AM
