Brake warning light says "BRAKE" in red
Old Aug 29, 2013 | 11:49 AM
imsven's Avatar
First, back in July I had posted about the voltage from my APPS. Thank you for telling me about reset of the APPS, I did it and it worked.
Now my BRAKE warning is on all the time. It is not being triggered by the emergency brake, I have checked it out and it is working properly. Where do I look now? could it be my ABS? and if so check what and how? My truck is a 2001 ext cab, full bed, 5 spd stick, 5.9 Cummins
Thanks,
Will in MO
Old Aug 29, 2013 | 11:53 AM
Numidian's Avatar
I would start by just checking your brake fluid...
Old Aug 29, 2013 | 01:15 PM
VADSLRAM's Avatar
X2 on brake fluid.
Did you futz with the switch that is activated by the brake pedal? They are a funky bit of over-engineering. If you pulled out the switch you can't just put it back, you have to reset it. Otherwise the comp thinks the brakes are on all the time and throws an error.
Old Aug 30, 2013 | 04:48 PM
DodgeCowboy's Avatar
DTR's Cow Boss
Also if the brake and abs lights on it could also be the front wheel bearings and outter ball joints when they fail the tip of the sensor hits on the axle housing and trips the computer.
BUSAHAULER
16
Feb 20, 2007 06:13 PM
PsRumors
Mar 3, 2006 05:45 PM
mt72916
Feb 1, 2005 08:00 AM
msthomas
Jul 22, 2003 07:53 AM
