Brake caliper ?
Old Jul 18, 2009 | 09:55 PM
Twodiesels's Avatar
Brake caliper ?
I broke the bolts off the brake caliper bracket. Can you buy the bracket holder seperately, or do you have to buy the whole unit?
Thanks!
Old Jul 19, 2009 | 08:08 AM
nickg's Avatar
on an 02 you can buy it seperately. There is an excellent brake mod that allows you to instal 3rd gen brakes, but inorder to do it you need 17inch rims. I'll find a couple posts for ya.
Old Jul 19, 2009 | 08:10 AM
nickg's Avatar
https://www.dieseltruckresource.com/...+brake+upgrade
Old Jul 19, 2009 | 08:14 AM
nickg's Avatar
also you should be able to unbolt the bracket and while in a vice drill the broken bolt out, or use a chisel and walk it out, alot of times when the bolt breaks the stress comes off the bolt and it can be spun out with a chisel.
or if you have a mig/welder. you can weld a nut to the broken bolt and 9 outta 10 times it will unscrew easily
Old Jul 19, 2009 | 11:03 AM
Twodiesels's Avatar
Thanks Nick! I have drilled, heated, tried easy outs and cant get it loose. Both bolts on the drivers side and one on passenger side broke. Guess I have to buy both sides. Thanks for the help really appreciate it.
Dan
McGyver
15
Dec 1, 2004 11:15 PM
spitzair
Oct 26, 2004 09:28 PM
joel
Sep 6, 2004 08:04 AM
dsljunkie
Feb 17, 2003 03:37 PM
dalef
Dec 13, 2002 02:51 AM
