boost gauge
Old Mar 3, 2009 | 07:15 AM
jacob_armour's Avatar
boost gauge
i want to put a boost gauge in my 2000 2500 is there a plug in the intake you can take out and intall a hose or is it a big deal
Old Mar 3, 2009 | 08:23 AM
2500Ram's Avatar
Yup, search boost bolt and just about every diesel shop sells them.
Old Mar 3, 2009 | 08:44 AM
a77ssii's Avatar
Boost took me about 15 minutes to install, it's the pyro that was a little more time consuming since I had to drill the exhaust manifold. Here's a pic of where my boost is tied in at. There was a small square head plug in the hole I removed to install the nipple.
Old Mar 3, 2009 | 08:49 AM
MSquare's Avatar
Easiest way is to get a "boost bolt" from one of the vendors.
Old Mar 3, 2009 | 09:00 AM
a77ssii's Avatar
Personally I went to the hardware store, pulled the plug and got a compression fitting that had the same thread and took the same size capillary tube as my gauge. Cost like $1.25, I only have a 3 month window to order and have FedEx or UPS deliver then our hill is ice and they won't chain up to come up here.
Old Mar 3, 2009 | 10:01 AM
infidel's Avatar
Instructions for pre '98 12 valves don't apply to a 2000, the plug is in a different place and totally different.
No need to buy a boost bolt unless you like to spend money
On the 24 Valve the boost pressure port is a 3/4 inch pipe plug requiring a 1/2 inch square drive ratchet extension for removal and is located on the side of the intake rearward of the fuel filter bracket.
You can't miss it and it's actually easier to get at than on a 12 valve.
You will need a 3/4" X 1/8" reducer from the hardware store unless your gauge came with one.
Old Mar 3, 2009 | 11:36 AM
nkennedy's Avatar
If you buy the boost gauge from Genos they trow the boos bolt & a gauge mount in for free. Gauge is around $53 to your door.
gpshemi
3rd Gen All Products
0
Jul 19, 2015 06:25 PM
Tank_66
Feb 28, 2008 08:34 PM
turbomike
Dec 3, 2007 09:31 PM
MoparMarv
May 4, 2006 04:41 PM
CRXsi
Mar 31, 2006 07:56 AM
