bhaf tubing, boots, elbows bends etc
Old 04-18-2016, 08:27 PM
cutthroatxxx's Avatar
Ok so I an wondering what kind of boots you guys used & pipe & degree of bends, length etc did you use for your bhaf set up? As I'm about to start trying to piece what I need together. Any pix you guys have would be great! Thanks in advance
Old 04-20-2016, 04:17 AM
AlpineRAM's Avatar
For mine I used the heat shield template, some 1.5mm aluminium sheet metal, 3 nuts, 3 short pieces of rubber hose to cover the nuts and the stock intake hose.
I just clamped it onto the BHAF and this worked fine for more than 100 k miles.
Only thing that was a little problematic was that the BHAF was slippery, but a shop rag and some brake cleaner took care of that.
HTH
Old 04-20-2016, 10:18 AM
I don't like this. Cause I'm looking to go with something a little cleaner looking
Old 04-20-2016, 12:19 PM
KATOOM's Avatar
If you want a clean look then get a hold of aFe and see if they have any Stage 1 Cold Air Intake System shield/box for the air filter but without the filter. Its almost identical to the DIY heat shield schematics found online for these year trucks. Trouble is the Stage 1 filter system has been discontinued and replaced with the Stage 2, so I couldn't say if they have any more but its worth a call.
Looks like this.
subs1000w
06-06-2007 06:10 PM
Cowboy_Customs
02-20-2007 12:24 PM
Patrick Campbell
03-23-2005 01:29 PM
gunracer1
10-12-2004 05:07 PM
Quick Reply: bhaf tubing, boots, elbows bends etc
