Bad steering problem
Old Oct 29, 2003 | 11:50 AM
Tackett's Avatar
I was in a parking lot yesterday and backed out of my space while turning a little. I stopped, dropped it into drive and turned the other direction. As I started to roll forward, I heard a loud "clunk". Sounded like metal on metal. I looked and couldn't find anything, so I drove on.
As soon as I hit the road, I realized that the steering wheel has to be 90 degrees CCW to go in a straight line (if the wheel is in it's normal "horizontal" position, I turn to the right).
I was less than a mile from home, so I drove slowly. When I got to my street, I swerved back and forth - slowly at first, but slowly going faster and harder. Nothing odd happened.
I got the front end up in the air, and moved everything back and forth. It all moves just fine, and there's no shiny spots (no newly exposed metal). I took it out again, and the thing drives exactly like it did before the change - but the wheel has moved.
I'm guessing that a splined shaft (somewhere) slipped by one spline, or perhaps the steering box is toast.
Any thoughts?
'97 4x4, stock except for 285/75/16's
Thanks,
Tackett
Old Oct 29, 2003 | 01:03 PM
richard's Avatar
Re:Bad steering problem
I would check the ball joints. This is much easier with two people. One to move the wheel up and down with a bar, the other to see if it is the upper or lower joints.
Rich
Old Oct 30, 2003 | 11:33 AM
Tackett's Avatar
Well I figured out why I couldn't find any problems in the steering... It was the rear axle. The driver's side rear axle moved back about 3" - there wasn't much holding it on at that point.Not sure what happened, but I'm guessing that the U bolts flexed, wore out or ???
I don't like that Chrysler has 4" lift blocks on a stock truck, but I don't have many options at the moment.
I'm putting it all back together, and will be replacing the Ubolts. Any thoughts on where to get them?
Thanks,
Tackett
Old Oct 30, 2003 | 01:21 PM
MnTom's Avatar
Find your self a spring shop. They can make 'em while you wait.
Tom
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
design
Mar 3, 2003 07:07 PM
doomgaze
Feb 6, 2003 06:51 PM
