Back seat squeek
Old Mar 15, 2005 | 11:24 AM
MARKY MARK's Avatar
Question Back seat squeek
Anybody ever had a squeek coming from the back seat? I can't seem to track it down. Seems to depend on the humidity and weather conditions as to wheather it squeeks. It also squeeks more when passangers are sitting on the seat. Any ideas?
Mark
Old Mar 15, 2005 | 01:33 PM
I PASS GAS's Avatar
Check the stops for the rear doors. Those were squeeking on mine. Same thing, only happened in certain weather. I put baby powder on them and it stopped. Doesn't last long though. I thought about a spray lithium grease, but that could get messy when getting in and out. Any suggesions on what to use?
Old Mar 15, 2005 | 03:01 PM
CanuckCTD's Avatar
This is the start of a joke right??? Sorry, mind is permanently in the gutter
Old Mar 15, 2005 | 03:10 PM
MARKY MARK's Avatar
That's a good one CanuckCTD!!
Old Mar 17, 2005 | 10:21 AM
Mike Perez's Avatar
Mark,
If the squeek is in the back behind the driver (driver's side) it could be the fuel tank. I had this simular problem with my truck. Mine sounded like it was from the back seat, so I got under the truck and had someone stand in the bed and rock up and down to move the suspension.
The fuel tank rubs against the back wall of the cab, or should I say, the back wall of the cab sits on top of the plastic fuel tank. If you can look between the cab and the bed from above you can see the black fuel tank.
You need to get under the truck and reach above the fuel tank to spray the contact point. Every six month to a year I have to respray, or if I go through water that washes off the lube.
I hope that's it.
MP
Old Mar 17, 2005 | 10:54 AM
MARKY MARK's Avatar
Mike, thanks for the post. Yes, it sounds like it's coming from the driver's side of the back seat. I will check that out tonight.
Old Mar 17, 2005 | 10:50 PM
MARKY MARK's Avatar
Mike. I checked the fuel tank and you are right. It looks to be rubbing...just barely. I sprayed some lithium greese where it contacts and will see if it helps. Thanks. Mark
Old Mar 18, 2005 | 06:46 PM
Mike Perez's Avatar
Mark,
I'm sure it will solve the problem, let me know.
Old Mar 18, 2005 | 06:50 PM
doodah's Avatar
I have the same squeek! but mines from the car seat on the leather seat!
Old Mar 18, 2005 | 09:37 PM
JKM's Avatar
JKM
Try usin the front seat and see if it still squeeks
04 Diesel
35
Sep 8, 2009 08:43 PM
bigsam
Aug 20, 2005 09:29 PM
Txwelder
Jun 3, 2005 07:34 PM
Ken W
Jul 23, 2004 05:24 PM
MARKY MARK
Jun 12, 2004 10:24 AM
