back glass replacement
Old Aug 17, 2012 | 11:56 PM
rockwithjason's Avatar
i broke my back glass when a load shifted and punched out the driver's side. has anybody done a replacement on these? any recommendations on replacement units? tips and tricks appreciated.
Old Aug 18, 2012 | 10:41 PM
SIXSLUG's Avatar
Use a buddy to hold the new glass in place on the bed side. You want the window seal installed on the glass itself and run a piece of 1/4" rope inside the seal all the way around with the two ends hanging out at the bottom center or top center of the seal. Spray the entire thing with silicone spray and get the seal started inside the lip on the cab and pull the rope towards you.
This will pull/fold the seal lip over the cab lip quite easily.
Boom, you're rollin again.
Old Aug 18, 2012 | 11:30 PM
Russ Roth's Avatar
The glass is glued in and uses no gasket.
Old Aug 19, 2012 | 01:34 PM
SIXSLUG's Avatar
Well, I guess that is not going to work then, is it!!
I solemnly withdraw my earlier posted instructions.....
Old Aug 19, 2012 | 08:11 PM
whiskers's Avatar
Did they change them from '97 ? I got one of those in my shed and it goes in like sixslug said.
Old Aug 20, 2012 | 12:20 AM
Russ Roth's Avatar
'97's use gaskets, the '99 and up are glued. Don't know about the '98's. I just sold one yesterday that came out of a '97 since I can't use it on my '01.
Old Aug 27, 2012 | 09:59 AM
Redlinear's Avatar
"almost" have to get a new glass. The moulding will be made to it, as part of the assembly.
Try a glass shop for this job. Yeah, you "could possibly" do it, but, you stand a good chance at messing up the paint around the glass when cleaning it up for the new glass to be glued back in.
Heat knife works best.
Sawing with a wire (piano wire) works if you don't care about the paint.
That has to be one the worst back glasses to remove without hurting the moulding or the paint.
Old Aug 27, 2012 | 12:26 PM
johnh's Avatar
if it was mine, i would spend a little more and get a slider
Old Aug 27, 2012 | 12:29 PM
johnh's Avatar
by the way, mines got a gasket
Old Aug 27, 2012 | 02:59 PM
Redlinear's Avatar
But, ya still gotta get all that old glue and broken glass off of it.
Old Aug 28, 2012 | 01:05 AM
Russ Roth's Avatar
Shouldn't have if it is the '01 in your signature.
Old Aug 31, 2012 | 10:10 AM
johnh's Avatar
its got an after market slider
Old Aug 31, 2012 | 09:20 PM
Russ Roth's Avatar
My local glass shop indicated there was no way to do that. Wonder how that happened? Or maybe it just looks like it has a gasket?
Old Sep 2, 2012 | 08:03 PM
i opted to replace my slider with a single glass. a local shop will do the job for about 200. the sliders are broken into here way to much and i never liked it anyway.
Old Sep 3, 2012 | 09:36 PM
totalloser's Avatar
Pay a BODY SHOP to do it. It's a tricky job. Not a do it yourselfer kind of thing. The rear on these there are two 90 degree turns to get to the seal, and there's paint to ruin on these surfaces.
ncj01
Apr 26, 2014 01:36 AM
2007ctd
Aug 9, 2010 02:41 PM
RHC
Sep 7, 2008 08:19 PM
jknowles4
Nov 21, 2007 08:45 PM
