alternator on 2001...burning smell and a little smoke
Old Oct 26, 2008 | 05:12 PM
bobem12's Avatar
hey guys, I have a 2001 2500 with 165000 miles. I was on the highway today and started to smell something burning, when I got home I popped the hood and I could see what looked like a little smoke or steam coming off the alternator and thats where the burning smell was coming from. I'm guessing the alternator is shot? I probably shouldn't drive it at all like this should I? I don't want the dang thing to catch on fire. I did a search but couldn't find anyone who said there alternator was literally burning up which is what mine seems to be doing. I guess my main question is should I go ahead and go to the parts store and pick up a reman? I would think it'd be an easy job.
Old Oct 26, 2008 | 06:39 PM
bobem12's Avatar
one more thing, what am I lookin at as far as used parts go? The build sheet for my truck says 136 amp alternator. Would any alternator off say a 99-02 diesel thats 136 amp work for me? I can pick one up off ebay for 50 bucks I think.
Old Oct 27, 2008 | 12:32 PM
mopar-or-no-car's Avatar
Do you have a/c? On my truck I had that burning smell awhile ago and smoke coming up from that side of the engine, I thought it was the alternator but I had recently replaced it. It turned out to be the ac compressor clutch was seized up and making the belt burn and its under the alternator so thats why I was thinking it was the alternator. Take the belt off and try spinning all the different things by hand and see if they alll rotate freely.
Old Oct 27, 2008 | 03:11 PM
tx_2500's Avatar
Removing the belt is easy. Use a 1/2" rachet or breaker bar on the tensioner. If your alternator insides feels "gritty" when you spin the pulley your bearings are more than likley shot.
Old Oct 27, 2008 | 04:41 PM
bobem12's Avatar
thanks i'll try that stuff
Old Oct 27, 2008 | 05:34 PM
bobem12's Avatar
well its definitely not the ac clutch, that spins perfectly freely. The alternator did not feel "gritty" but harder to spin then the ac clutch. It spins smoothly but you have to put your hand on the alternator and turn it like a **** whereas the a/c clutch i could roll a finger down and make it spin. what'dya think?
Old Oct 28, 2008 | 01:24 PM
Fueling around's Avatar
The A/C clutch and alternator spinn sounds normal. The A/C clutch disengages so you basically turn the pulley. The alternator doesn't have a clutch so you spin the rotor.
Get your batteries tested. If they both test good then get the alternator tested.
Old Oct 28, 2008 | 03:06 PM
tx_2500's Avatar
Well, just because the bearings arent gone does not mean all is well with the Alternator. If you saw smoke comming from it you still need to get it fully checked out. Burning up your truck would be a bad thing
Old Oct 28, 2008 | 05:55 PM
bobem12's Avatar
guys on another forum said that they thought the bearings on the alt were warped...I went ahead and did a best offer on ebay and got one for 50 bucks shipped. Used but its from a used parts guy and they said it was tested so hopefully that fixes 'er up
I don't think its the batteries. I just got the truck 6 months ago so I'm not sure how old the current batts are but they are everlast I think. So since the trucks an '01 and the stock batteries last awhile these can't be that old can they? I haven't had any electrical or starting problems (knock on wood)
Old Oct 29, 2008 | 01:09 AM
dozer12216's Avatar
You don't want to burn something up so stop guessing and get batteries tested free at wally world. Pull alternator and get bench tested at parts store. Testing on vehicle is problematic. One bad battery will will make alt work like crazy to get voltage up
Brps
Apr 24, 2013 08:18 AM
wackodacko
Jan 9, 2010 11:19 AM
Doj Dewd
Aug 24, 2009 09:17 PM
rriddy
May 12, 2008 11:15 AM
aklabs
Apr 2, 2004 01:05 PM
