ac control switch
Old May 31, 2009 | 09:00 PM
bigjohn862's Avatar
ac control switch
ac working great but i had it on defrost now it wont change to anything else.Do i need to replace this whole dash switch??
Old May 31, 2009 | 11:19 PM
Mike D's Avatar
Check all your vacuum lines, also look under the dash at the blend door.
Old Jun 1, 2009 | 09:45 AM
infidel's Avatar
A leak anywhere in the vacuum system causes the climate control to default to defrost.
Check under the hood in any area you were recently working for an accidentally disconnected hose.
Old Jun 3, 2009 | 03:38 AM
JasonblkZ06's Avatar
Every post is about some A/C problems. Too bad Cummins come with a Dodge. Crap Chrysler a/c systems.
Old Jun 3, 2009 | 06:48 AM
RGBruce3's Avatar
The same thing occured to me yesterday, defrost only, cannot turn the system off. Also lost my fan control, blows one speed only. Temperature control still operatative. You guys still think I should be looking for a vacuum leak? Thanks.
Old Jun 3, 2009 | 09:52 AM
infidel's Avatar
Easy to tell if you have a leak.
After running the engine let it sit for five minutes.
Disconnect any vacuum hose, if it doesn't hiss you have a leak.
A leakless system will hold vacuum for days if not weeks.
Old Jun 3, 2009 | 10:37 PM
bigjohn862's Avatar
Found hose with leak in it all is well.
Old Jun 4, 2009 | 12:22 AM
nickg's Avatar
You have two seperate issues, vacuum leak/no vacuum, this is the reason for defrost only.
the fan speed is most likely because of a blown blower motor resister (under dash near fan motor) some have reported having soldered the broken coil, another reason for failure could be a Fan motor thats drawing too much current and popping the resistance coils in the resistor, or something to that effect.,
Old Jun 4, 2009 | 09:45 PM
bigjohn862's Avatar
Mine just went to defrost but it would still turn off.
Old Jun 8, 2009 | 08:31 AM
RGBruce3's Avatar
Tracked down my leak this weekend. It was in the plastic vacuum line above the AC accumulator/dryer. I cut both ends clean, inserted a small stainless steel tube and sealed the splice with RTV black. All is well. Thanks guys.
Old Jun 8, 2009 | 12:18 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Agree...I'm fighting with mine also...And everything is darn expensive when dealing with AC...Including the cost of evuating the system and recharging just to find the problem..
92smokin blacky
Sep 1, 2010 09:55 PM
grizzly660fan
Jan 2, 2004 10:02 AM
TexasDiesel
Dec 27, 2002 10:47 AM
