ABS and Park Brake lights on
The lights have been on in my truck for about two years now or more and everything still works. If there is a wire running along the front brake hose to near the calipers, you have ABS all around. I haven't bothered to fix it because I hate ABS more than the lights being on. One of these days, I'll get a new sensor.
I'd convert both of mine to 4-wheel ABS if I could.
Chris
Originally Posted by dodgechick98
My brake lights don't stay on, but I have had my seatbelt light come on and stay on. Its every so often though.
Originally Posted by hekroh
Are there any problems if you do not change the sensor right away?? My lights went on over the weekend and I do not know how long it will take till I have time to replace the sensor....
It won't hurt anything except you won't have ABS, just regular braking.
Originally Posted by jturuk
I was looking through the repair manual the other day and read that on some of the onboard control modules if a malfuntion is rectified and the vehicle restarts something like 50 times without seeing that malfunction it will reset itself. So assuming that the speed sensor is the problem I'm crossing my fingers that the dashlights will eventually reset.
When you get the new sensor in you can just unhook the batteries for 10-20 minutes and the computer should reset itself.
Originally Posted by Stamey
Man, ABS is the best thing since sliced bread, if you let it do it's magic. Although my truck doesn't have it, neither one, by BMW does and it has saved my butt more than once. Being able to slam on the brakes as hard as you need to, and still maintain control of the vehicle, that's EXCELLENT!
Chris
Chris
i'm glad my truck is RWAL but the abs light and brake light have been on for about a year now with no ill results..... on the abs deal..... abs is the reason i ended up in a ditch with my expedition with an empty car trailer behind it..... i could threshold brake better than that abs did..... petal went to the floor i heard the abs pump kick on and the truck didn't feel like it was slowing down any...... 180* later and a jacknifed trailer and i was being pulled out of the ditch by a chevy.... oh well that's why i got a real truck to tow with....
where to buy speed sensor?
I have this same problem, abs and brake light on. Brake place said they thought it was the rear speed sensor and wanted a $100 to replace it. I passed thinking I could buy it from an autoparts store. But to my surprise the 3 different autoparts stores I contacted dont even list the sensor! How can I replace it if I can't buy it? Is this a dealer only item? I was hoping to save a couple bucks and replace it myself, but now I dont know. Where have you guys purchased yours?? Thanks
Grounding
I had this same problem on mine and found it to be the ground wires coming off of the ABS module were loose at there connection points on the rear frame/front left fender. Once these were sanded and tightend down-----PROBLEM FIXED!!!!! Always check the source first before replacing parts!!!!!!
Problem solved
Thanks everyone for their input. I installed the speed sensor today and not only did the speedometer start working but both the ABS and Parking brake lights both went out. Didn't sound like they were supposed to but they did, much to my surprise.
John
John
93-12Smoke
Aug 28, 2011 12:22 AM
polaris800sp
Nov 13, 2008 05:35 PM
sssmaly
Jul 13, 2007 12:57 PM
